| Junior Member Join Date: Nov 2008 Location: Wilkesport, ON
| Engine Question Hi folks. i got an 89 chevy silverodo with a screwed 350 in it. and i was wondering if a 305 out of a 91 chevy caprice will line up to the existing motor mounts. if not is it alot of work to make it fit? thanks |
| Well lets see here If i am not mistaking I belive they should be the same motor mounts its still a 8 cyclinder im 99 % sure
__________________ //B-rad |
| ok. thanks
__________________ driver like you stoler |
| wow what a fast reply!! lol! wait for some other opinions before you start the project
| Banned Join Date: Nov 2008
| Your best bet will be to take the mounts off the 350 in the truck and bolt them to the 305. That way it should easily slide right in, and guaranteed to fit. Good luck. |
| lol no. just got a looking around the site. im new here
| you won't be happy with the 305. not because of it's size but for the fact that it was a car engine. car and truck engines are set up different, you won't have the low end torque that truck needs.
| Senior Member Join Date: Jul 2008 Location: tallahassee, fl
| arent the oil pans and pump pick up different as well they will also have to be switched,the car and truck engines have different grinds on the cam it can be done but not worth putting a 305 in a truck.
__________________ 2004 gmc 1500 cc 4x4 |
| I believe the oil pan and pump are the same, so there shouldnt be any clearance issues. Yes, the cams are different, but so is the rest of the engine. The 305 wont perform like the 350, but it will keep his truck on the road. |
| ya lol the only reason im puttin the 305 in is just to keep in goin. i cant get my hand on a 350
| Vortec engine question | area1509 | GMC Truck Forum | 22 | 11-25-2008 08:34 PM |
| Engine ID number question | goatman | Chevy Truck Forum | 2 | 08-20-2008 01:26 PM |
| Engine Swap Question. | Pantharen | Mazda Truck Forum | 0 | 05-31-2008 08:26 PM |
| 1964 Truck engine question | bosler | Ford Truck Forum | 4 | 12-22-2006 09:49 PM |
| Engine pulling question? | claytonfrnk | Chevy Truck Forum | 7 | 09-06-2006 02:26 PM |
