| Junior Member Join Date: Nov 2008 Location: SE michigan
| Won't go into 4WD My 94 S15 will only on into 4WD if the key is in the ACC position. If the key is in the Start position the lights on the 4wd switch flash showing the system is working but it will not go into 4WD. Any help will be appreciated. |
| Senior Member Join Date: Oct 2008 Location: NW Arkansas
| Sounds like a bad connection of some sort. Or something is grounding out.
__________________ http://s513.photobucket.com/albums/t...t=HPIM1105.jpg '76 Silverado10 Custom Deluxe, 350 4barrel, th350 auto FULL TIME FOUR WHEEL! |
| Welcome to the forum do you mean the run position not the start because it will not activate while the starter is turning
__________________ 4 wheels move the body 2 wheels move the soul B.W.A.I Last edited by leolkfrm; 11-28-2008 at 05:55 PM. |
| not run. if i remember right, 94 had a selection that you turned the key backwards to. are you in park or neutral when you are putting it into 4wd?? |
