Old 11-30-2008, 12:40 PM   #1
Jayhawk is on a distinguished road
1990 Chevy Shortbed Electrical light problem
Hi there,
Hope someone can steer me the right way.
All lights in the back are not working.
here is what i have done
1. Replaced all lights in the tail lights.
2. Replaced the neutral/safety switch
3. Replaced the other switch right by it connected to the the brake pedal.
4. Replaced the circut boards on the lights.
Before I did #4 only the drivers taillight was on with the ignition off. If I moved the turn signal doen, the light went off.
There are no brake lights when you push on he pedal.
Has no trailer harness.
With the truck off. The rear lights are on. I disconnected the plag at the rear of the truck. There is power coming from the front of the truck on the yellow and one of the green wires.
Any suggestion on where to go from here?
Jayhawk is offline   Reply With Quote
Old 11-30-2008, 02:33 PM   #2
welcome to the forum
I would keep tracing forward and look for a bad spot in the harness, maybe its rubbing
Old 11-30-2008, 02:38 PM   #3
silverhairdeere's Avatar
the same that was wrong with mine . mis adjusted brake switch , drove me crazy trying to figurer it out .
silver hair deere
dead battery thing ?
Old 11-30-2008, 04:44 PM   #4
How would that explain the two wires having power to them? I bought a turn indicator switch today. Soon as the rental steering wheel puller comes in, I will change that out.
On the wiring diagram, those two colored wires go to the the rear lights.
Thanks for the tips. I will psot as soon as I change them out and se what the results are.
Thanks
Ron
Old 11-30-2008, 05:42 PM   #5
if you have power back there, i would check continuity on the ground side.
Old 11-30-2008, 05:53 PM   #6
explain that process if you don't mind. I kind of know what you are talking about.
thanks
Old 11-30-2008, 06:00 PM   #7
you have a ground wire that comes from the lights and heads back up front through that plug. take a multimeter and trace the ground wire down to see if it has seperated. that would indeed cause your lights to not work. start with the plug and go backwards towards the lights. yank the bulb and test for continuity there. if that checks out, go on the opposite side of the plug and work your way back to the front of the truck.
Old 11-30-2008, 07:37 PM   #8
before you tear everthing out , please try reajusting your brake pedal switch .
silver hair deere
Old 12-04-2008, 06:27 AM   #9
any update ?
silver hair deere
Old 12-07-2008, 05:10 PM   #10
Here is an update.
Replaced:
5. Replace turn signal switch.
6. Replace turn signal flasher
Adjusted the thing you showed in the picture. Tail lights are off now.
Everything works fine with the headlights off. All brake and turn signals
When I turn the headlights on, one tail light does not work (drivers). When I turn the the right turn signal on the reverse light flashes on left side and the reverse light and the light above the reverse light on passenger side alternate flashing.
So what now? I think I will go though all the bulbs again to make sure they all work and are the correct ones.
2000 Chevy Blazer dome light problem TerrieM Chevy Truck Forum 8 11-21-2008 11:51 AM
FS 1981 chevy shortbed 2x4 donaldson.c.m Truck Classifieds 2 05-14-2008 07:54 PM
1990 chevy 1500 problem e brake light josh030181 Chevy Truck Forum 2 08-27-2006 12:29 PM
1997 chevy tahoe gage light problem bajaboy Chevy Truck Forum 5 03-23-2006 08:58 AM
Parting out/1990 Chevy Silverado shortbed stepside Volare80 Chevy Truck Forum 0 03-06-2005 08:06 PM
