| Engine shutting off when hot Hello i have a 2000 chevy c2500 with a 5.7 350 recently i have had problems with my truck shutting off when running hot or when in stop and go traffic i already changed my fuel pump fuel injectors engine heat sensor ignition coil trottle position sensor and im running out off opinions can anyone help please! |
| Welcome to the forum Scan it and see what the sensors are doing. Drive it with the machine hooked up till it quits and I'm sure the solution will show itself
| the only codes i get are bank 1 and bank 2 running lean and i forgot to mention that my truck will start after letting it sit for a wile and cool off! |
| leo's right, you will have to use a scan tool to figure it out. if you haven't cleared the codes yet, then pull up the freeze frame data. there's not a lot of info on the freeze frame, but it's a start in the right direction. |
| Thank you i will try that if anybody has any other tips i can realy use them! |
| reading codes is great if it's a simple fix, a scan tool actually reads the sensors, so when it quits you should be able to tell which sensor is doing it. the cost of a good scan is far less then the money you have spent and not finding the solution
| Thank's for everyone's help i will let you know what happens! |
| i ran my truck with the code reader and nothing came up no codes at all i recently put headers on my truck and many people say that maybe they are creating to mutch heat in my engine bay therefore causing this problem! maybe my pcm is shutting off my fuel! when the temp gets to high what do you guys think about this! |
| Sounds like nonsense to me, I'm a few others will agree. As i said earlier you need to use a scanner not a code reader. You can moniter the engine while driving with a scanner, and it will most likely give you the best idea of your problem. Did you use headers with a o2 sensor port? What else did you do that you have not mentioned?
| sorry i my mistake i was confused. anyways i did use the correct headers for my truck but i dont think there is a O2 port in the headers all off my sensors are after the headers. the only thing in the headers is a heater hose so i think! anyways i will get a scanner and check it out. ohh yeah the headers is the only thing ive done to my truck, Thank you verry much. |
| Tags |
| o2 sensor |
| Engine misfire detected engine code HELP | Airforce wrench | Chevy Truck Forum | 2 | 02-21-2008 07:13 PM |
| Looking to up my engine.. | BryanCregger | Chevy Truck Forum | 1 | 03-25-2007 01:11 PM |
| 96 K1500 Just shutting off while driving! | Charles1221 | Chevy Truck Forum | 2 | 08-02-2006 08:17 PM |
| Engine ID | 74pilot | Chevy Truck Forum | 3 | 11-28-2005 08:24 AM |
