| Junior Member Join Date: Aug 2008
| 94 Silverado 3500 HD speedometer wont work What can be wrong with a speedometer? I've removed the panel and it is all electronics, no cable, I've cleaned thhe contacts, nothing helps. Where is the speed sensor on the 6.3 ( 6.5?) diesel??? Thanks |
| Full Member Join Date: Nov 2008 Location: motor city
| a sensor on the tail shaft of the trans? |
| Full Member Join Date: Feb 2006 Location: Indiana
| Hi, I replaced the speedometer cluster in my 1992 GMC bucket truck. I found a schemetic that told me basically how the system worked. There is a electronic sensor that counts the lobes on a gear type ring at the output of the transmission. This puts out pulses of electric current every time a lobe passes the sensor. This input is fed to a VSS ( Variable speed sensor) mine was located behind the glove compartment. The VSS converts the changes the pulses input to a different number of pulses output to allow for the difference in the rear end ratio and the size of the rear tires to make sure the speedometer reads correctly. There are jumpers in the VSS that are cut to calibrate it. This output is then fed to the guage cluster to operate the electronic speedometer. Good luck on the restoration |
| Tags |
| 3500 hd, silverado, speedometer |
| Chevy diesel 3500 HD wont move | dspabout | Chevy Truck Forum | 6 | 10-23-2008 05:47 AM |
| 94 chevy 3500 w/ 265,000 miles wont shift | DaveF | Chevy Truck Forum | 8 | 08-16-2008 06:14 PM |
| Speedometer doesn't work! | anahataray | Dodge Truck Forum | 6 | 01-31-2007 05:05 PM |
| ac wont work | rrrssm | Chevy Truck Forum | 3 | 08-14-2006 07:41 PM |
| 1992 Chevy 3500 HD Speedometer problem | fisher429 | Chevy Truck Forum | 0 | 02-06-2006 07:35 PM |
