| Front differential grinding 2001 s10 I have a 2001 chevy s-10 which is making a grinding noise in the passenger front differential intermittantly. Sounds like two gears trying to mesh out of sync.I have replaced a ton of front end parts which include....uper and lower ball joints,all cv joints brakes,calipers wheel bearings and the actuators switch located on passenger side of front differential. It still makes the noise occasionaly and after you drive it a while on the interstate. When you stop or enguage four wheel drive the noise goes away.ANY SUGGESTIONS ALSO WHERE PART IS LOCATED THAT NEEDS TO BE CHANGED. |
| Senior Member Join Date: Jul 2008 Location: tallahassee, fl
| going by his reply i dont think he will answer i am not sure where it is i would go to gm or local parts store and ask for the part and match it up.
__________________ 2004 gmc 1500 cc 4x4 |
| sounds like for some reason the actuator is not letting the shaft in the differential fully release or something is wore in that area. try disconnecting the wire to the actuator and see if it goes away. If not I think a rebuild of the diff is in your future
| Grinding from front when making left turn | FIRSTTRUCK | GMC Truck Forum | 7 | 10-26-2008 10:49 PM |
| front wheel bearing/hub assembly on a 2001 Dodge Ram 1500 | Space Ace | Dodge Truck Forum | 10 | 10-09-2008 09:38 AM |
| 2001 Ram 1500 front axle woes | metal cowboy | Dodge Truck Forum | 1 | 08-12-2008 10:25 PM |
| Front Differential Leak | Charlieb | GMC Truck Forum | 5 | 04-09-2008 11:45 AM |
| Front differential seals | mjeltema | Chevy Truck Forum | 3 | 08-20-2007 10:08 AM |
