Old 12-08-2008, 04:23 PM   #1
FATMAC is on a distinguished road
Angry Puzzeled
1992 k1500 4.3 sometimes it will start with the key and sometimes I have to push it and pop the clutch. never know when it will start with key, no special times hot cold ya never know. now what is happening seems could be battery. have charger on it now, so now I try to start and nothing the lights wont even work till it sets for a few minutes Any ideas?
FATMAC is offline   Reply With Quote
Old 12-08-2008, 04:30 PM   #2
PAPA BEAR's Avatar
PAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura about
welcome to the forum possible bad connection or corrosion on terminals hope this helps
PAPA BEAR is offline   Reply With Quote
Old 12-08-2008, 04:39 PM   #3
all clean at battery and terminals. just went out to try again charger down to 1-2 amps dome light was on and soon as I put on brake it went real dim almost off
Old 12-08-2008, 04:46 PM   #4
PAPA BEAR's Avatar
sounds like your battery is dead will it boost with cables
Old 12-08-2008, 04:57 PM   #5
have not tried cables, charger started out at 5 amps now down to 1
Old 12-08-2008, 05:05 PM   #6
PAPA BEAR's Avatar
are you close to a parts store most will check a batt for free
Old 12-08-2008, 05:13 PM   #7
no not close but if i get it started in morn. i will have boss check it. i did look back at a couple of other posts said to chk. ground at eng.
Old 12-09-2008, 10:22 AM   #8
Have a load test done then have them check each cell maybe one is bad, like I always say a bad battery will fool one big times and can cost you a lot of uncalled parts.
Old 12-09-2008, 02:14 PM   #9
Smile
well at 4 A.M. central IL. cold rain I found the prob. wire coming off of pos. cable going to relay on firewall!!!!! took off pos. cable again to make sure it was not corroded. found that the small wire was corr. about 1 in. back under the insulation. fired right up. my wife very happy she did'nt have to get up to take me to work!!!!!!!!!!!! thanks to all for any help
Old 12-10-2008, 07:19 AM   #10
relay on firewall is your fuel pump relay if it is like mine
