Old 12-11-2008, 02:22 PM   #1
num30footbll's Avatar
num30footbll is on a distinguished road
Question 1989 Chevy 3/4 Ton 1500
I have a 1989 Chevy 3/4 Ton 1500 with 4 wheel drive and a 6" lift and 33" tires. Recently the rear U-Joint went out and i successfully replaced that without much issue, i figured while I was doing that work I would replace the slightly damaged front U-joint before it caused me trouble. I removed the drive shaft all the way from the transmission to the rear diff. I have tried to pound out the U-joint but have been unable to do so. I have exausted all the common ways to remove the part and now am out of ideas. Anyone HELP??
num30footbll is offline   Reply With Quote
Old 12-11-2008, 02:54 PM   #2
gettembuilt is on a distinguished road
I used a crow bar removing mine and they normally break but i would replace them anyways !!
gettembuilt is offline   Reply With Quote
Old 12-11-2008, 02:57 PM   #3
A Crow bar??
How do you mean tht
Old 12-11-2008, 04:33 PM   #4
Kennyray's Avatar
Kennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to behold
Probably still has factory plastic retainers holding the caps. Heat the caps with a torch and use a viseto press them out after you heat them.
Kennyray is online now   Reply With Quote
Tags
chevy, removal, u-joint
1989 chevy 7.4 Motorhome John D Chevy Truck Forum 5 06-18-2008 12:01 PM
1989 Chevy S-10 won't start raydqt Chevy Truck Forum 1 01-07-2008 02:39 PM
1989 GMC Seirra 1500 Exhaust manifolds 1988monty GMC Truck Forum 13 07-13-2007 08:20 PM
1989 chevy value 396chevy Chevy Truck Forum 6 09-27-2005 11:23 PM
1989-1991 1500 6 lug wheels for sale in Michigan f16mania Chevy Truck Forum 0 03-21-2005 12:25 PM
