Old 12-14-2008, 05:43 PM   #11
88chevydually is on a distinguished road
i checked all the fuses and they were all good. i am getting some power to the truck because the interior light turns on when i open the door, and all the running lights turn on when i turn on the lights, but i will trace down the power wires and see what i find
88chevydually is offline   Reply With Quote
Old 12-14-2008, 06:12 PM   #12
93blazer's Avatar
93blazer has a spectacular aura about93blazer has a spectacular aura about
is there a fuseable link near the battery or near your altenator if so check them if i remember one goes to your fuse box have you checked power at the back side of the fuse box ?
**IF YOU AIN'T FIRST YOUR LAST**
SHAKE AND BAKE !!!!!!!!
93blazer is offline   Reply With Quote
Old 12-14-2008, 06:25 PM   #13
what does the fuseable link look like, and what am i looking for when i find it?
Old 12-14-2008, 06:27 PM   #14
93blazer's Avatar
it looks like a wire some you cant tell but most on chevys have i little rubber or platic berrall lookin thing on it ill try and find a pic for ya
Old 12-15-2008, 07:57 AM   #15
did you check for incoming power at the switch at the base of the column?
Old 12-15-2008, 04:57 PM   #16
what color is the incoming wire at the switchat the base of the column?
Old 12-15-2008, 07:09 PM   #17
I believe red, it also feeds the starter relay block. did you check #6 40 amp maxi fuse? there may also be a 10 amp crank fuse
Crank Pulley Bent? DVP Mazda Truck Forum 3 08-25-2008 05:56 PM
Crank Shaft Pulley Jessie Truck Classifieds 0 03-11-2008 04:13 PM
New to Forum and need HELP!! Bad Crank??? 61unibody Toyota Truck Forum 5 08-01-2006 05:37 PM
s10 won' crank steve39475 Chevy Truck Forum 7 03-28-2006 06:14 PM
87 Pickup Won't crank bbmjy8s Chevy Truck Forum 2 11-20-2005 11:49 PM
