| Automatic trans I have a 87 , 4x4. Th400 trans. Whe it warms up it doesn't seem to shift into drive. It will shift 1 to 2 but it takes a long time to shift into drive. I replaced the modulator today. Doesthe same thing. Fluid level is fine. What else can I check? Or am I looking at a rebuid ? |
| When was it serviced last? as in fluid exchange. is vac operated?
| is the fluid dark or smell burnt. if so a good start would be fresh fluid and filter.and maybe some Lucas . if the fluid is nice and red you may have some leaking seals internally if this is the case rebuild good luck |
| I'm not sure when it was las serviced. I will try that first. |
| Good luck! let us know how you make out
| add some lucas transmission treatment also . silver hair deere |
| Are you saying that when cold the 2-3 upshift is OK? Only delayed when hot? Have you checked the vacuum line right from the engine down to the transmission? Try unplugging the kickdown switch in case you have a problem there. |
| Tags |
| automatic transmission, transmission |
| 12/86 Nissan vg30 Automatic 4x4 | ron jeremy | Nissan Truck Forum | 5 | 11-29-2008 02:07 PM |
| Automatic or Manual | russty08 | Polls | 8 | 01-05-2008 11:02 AM |
| automatic headlights | firedispatch1 | GMC Truck Forum | 14 | 10-26-2006 06:51 PM |
| offroading manual or automatic | allegiancevft | Polls | 2 | 01-31-2006 06:25 PM |
| 93 GMC V6 Automatic | 93GMC-V6 | GMC Truck Forum | 3 | 12-21-2005 07:27 PM |
