Old 12-23-2008, 01:58 PM   #1
94silver is on a distinguished road
1994 Silverado Brake Lights
The rear brake lights on my 1994 Silverado 1500 truck have quit working. The over cab brake light works correctly. Here is what I've done so far.
1. Replaced the circuit boards in the rear lights.
2. Replaced the switch on the brake pedal.
3. Replaced the relay under the hood on the firewall near the brake master cylinder.
The turn signals work and since this truck uses the same bulb and filament for the brake lights and turn signals, I know the wiring is ok. I have tested the system with the trailer wiring connector in place and removed with no difference in results. What do I do next?
94silver is offline   Reply With Quote
Old 12-23-2008, 02:11 PM   #2
welcome to the forum
How far have you traced power or the lack off?
Old 12-23-2008, 03:35 PM   #3
I have power to the rear lights when the turn signals are working and they use the same wires and light filaments as the brake lights. How should I trace the power on the brakes?
Old 12-23-2008, 04:03 PM   #4
Well I know that the electronic circuit boards are always going out on them but first check your bulbs and all the connects on the board with a test light before your replace the boards.
Good luck! GMC
PS-Welcome to the forum and howdy from TEXAS I hope your stick around you can meet a lot of good folks here like me. He! He! GMC
Old 12-23-2008, 07:04 PM   #5
ok power to the tailight wire and to the stop/directional wire?
Old 12-23-2008, 08:03 PM   #6
John 424 is on a distinguished road
yea my 97 doing the same thing i thinks it just a fuse and my gages dont light up and brake lights don't turn on but if i press the brakes they work
John 424 is offline   Reply With Quote
Old 12-24-2008, 06:44 AM   #7
I have replaced the circuit boards, and the turn signal wire and the brake light wire is the same wire. I have power to it when I use the turn signals but not when I put on the brakes.
Old 12-24-2008, 07:23 AM   #8
How about checking to see if you have power from you brake switch under the dash or maybe it needs adjusting.
Old 12-24-2008, 07:43 AM   #9
I have power at the brake light switch on the pedal. The brake light over the cab works.
Old 12-24-2008, 08:27 AM   #10
do you have power on both sides of the brake light switch when you push on the pedal
Heater control back lights 1994 sierra redlineps GMC Truck Forum 2 12-22-2008 01:25 PM
'97 Silverado -brake signal wire for trailer brake controller mcZEd38 Chevy Truck Forum 6 05-17-2008 05:51 PM
1994 K2500 Suburban brake calipers '94K2500Sub454 Chevy Truck Forum 2 04-13-2008 08:17 AM
Brake Lights always ON!!!!! nnunez Nissan Truck Forum 5 10-12-2007 02:03 PM
Wanted: p/s fender, lights, and grill for 1994 GMC sierra Chris GMC Truck Forum 0 04-07-2005 12:14 PM
