| 700 vs 400 trans My 87 4x4 3/4 ton currently has a TH400 auto. I have a 700 trans from a full size blazer. What are the pro's and cons of these transmissions? Are they the same length so if I do the swap I won't have tochange driveshafts? Is the 700 as durable? I would think the overdrive on the 700 would help fuel economy a bit. Thanks for your help. |
| i like the 700s alot better that the 400s the 400s are excelent in the big cars but i love the 700 for the rucks cuz its built a little beter and it has over drive and realy couldn't tell ya on the lenth |
| Im not sure on the lengths....... the 400 will handle a lot of abuse.... the 700r4 have over drive, and the 1st and 2 gears are quite low.. I believe that they are close to the same as the th400... but not as tough.. unless you are willing to build them.. but for everyday use, a 700 would be My personal choice of transmission. |
| I have heard that the 700 has better gears in it for 4x4ing and so on. |
| Full Member Join Date: Nov 2008 Location: Warren, Ohio
| The gear ratio for the 400 is 2.48/1.48/1.00 and the 700r4 is 3.06/1.63/1.00/0.70 does this help any? |
| cs racing has the numbers that I was looking for....... the gears arent quite as low, but you gain one more gear... so highway you arent screaming at 70 |
| | #7 | |
PS- I know this is an older thread, but for those who find it, just needed to be properly informed. | |
| Full Member Join Date: Jan 2009 Location: yuba city California
| if you need overdrive and cant afford an overdrive unit to bolt onto a 400, then get the 700, but know that heat kills them quickly. to make it last you must run a heavy duty radial rv cooler and if your fliud out line is a 1/4 inch tap it out to 3/8, if your in line is 3/8 tapp it out to 1/2 inch. i killed a 700 quickly havent killed a 400 yet. A buddy did what I suggested to you (his idea not mine) and he pulls a 12000 pound trailer all the time with no issues |
| I had a th400 in my 84 3500 4x4 and pulled it to put in a 700r4. I had a heck of a time with the kickdown cable not staying adjusted, i would open it full throttle and push the thumb button down and it would be good for a while then all of a sudden, it would shift quickly into overdrive or stay in 1st forever. I replaced the cable and it seemed to have cured the problem. I will, however, be putting my th400 back in as soon as I get time. I tow quite a bit with this truck and it don't see the interstate very often so i really don't need overdrive. Just my 2 cents. |
| Good Idea Semo. I am glad to see this thread getting some attention. It was older when I posted on it, but I wasn't going to leave it untouched when I seen someone said a 700r4 is better built than a T400. NOT. By chance did you notice any kind of gain in fuel mileage with the 700r4?
| Trans fault | meanskins | Ford Truck Forum | 2 | 10-09-2008 06:52 AM |
| trans question | 93bluesilverrad | Chevy Truck Forum | 9 | 06-05-2008 05:03 AM |
| auto trans Q's | mtfit | Dodge Truck Forum | 1 | 12-21-2006 09:06 PM |
| trans help | metalbender | Chevy Truck Forum | 0 | 12-09-2006 09:10 AM |
| trans out | nate02 | Nissan Truck Forum | 1 | 05-17-2006 10:15 PM |
