Old 01-10-2009, 07:54 PM   #1
mainiac1 is on a distinguished road
Exclamation Removing carrier on Silverado posi Rearend
Hey Guys, new to the forum and need a little help. I've got a 2001 Silverado with a chewed-up spyder gear. I had intentions of swapping out the whole rearend, but the one I purchased turned out to be in worse shape than mine. Having trouble getting the thrust block rotated inside the carrier to remove it. I got the lock bolt and pin removed, but there are 2 spring loaded pin/teeth assemblies on the back side that won't let the block rotate to the front. Whats the trick for this?
I'm gonna try a thin piece of sheetmtal between the block and the pins tomorrow to keep them from engaging the block...hopefully unless someone has a better idea.
Thanks, Jamie
mainiac1 is offline   Reply With Quote
Old 01-10-2009, 09:07 PM   #2
if we're talking about the same thing, there was a member that just did this about a week or two ago. he was trying to change out his axle seals. do a search for axle seals on here and see what you come up with. maybe someone else will remember where that thread was too.
Old 01-11-2009, 06:17 PM   #3
Thanks Mudseeker
I did search the forum originally before I posted, but not under axle seals. I figured it out today...the thrust block has a hole in each side that allows the axles to be pushed in (if its not missaligned) and remove the c-clips. I was so intent on removing the block i overlooked the recess for the axles. The rest was piece of cake. Just gotta order the pass side axle drive gear tomorrow as the rest of the insides look good.
Thank you for the reply
Jamie
Old 01-12-2009, 01:38 AM   #4
I have heard that those rear-ends are worthless when using them with a LS engine that's a little souped up. They call them GRENADES because they blow up like one.
Old 01-12-2009, 04:37 PM   #5
Mine didn't go that far, but chewed up one spyder gear and wouldn't ya know Chevy only sells the gears as a carrier rebuild kit to the tune of $500.00!!!!
I need posi!!!!!!!!!!! Nates01Ram Dodge Truck Forum 7 10-26-2008 04:05 PM
1989 Carrier Bearing pdpo222 Chevy Truck Forum 4 05-06-2007 07:32 PM
Removing tow hooks on 2005 Silverado? Mad Scotsman Chevy Truck Forum 4 02-15-2007 06:29 PM
10 bolt rear diff with 3:73 limited slip carrier chevyguy Truck Classifieds 13 06-16-2006 09:21 PM
bad vibration after changing u joints and carrier bearing ohio larry Chevy Truck Forum 2 01-09-2006 06:28 PM
