| Full Member Join Date: Jan 2008 Location: Norristown pa
| Question about checking compression I want to check the compression on an engine before I pull it. Directions with the compression tester says to check it with a warm engine. I can't keep the engine running long enought to warm it up(it hasn't been run lately and was a farm beater truck). How different would the results be with a cold engine vs. a warm engine? I plan on selling the engine, it is in a truck that I bought for the frame, body is toast, engine was said to have been rebuilt. Thanks |
| it is kinda hard to sell an engine that you cant keep running. if you get a number that is way too low, no matter if cold or hot, than it is going to be bad. a cold cylinder should still be well above 100 psi. |
| Full Member Join Date: Jan 2009
| you should actuly tets it when it room temp. i work on sleds alot and when we test them we let them get to room temp and hold it wide open and pull it over to compression test it, i dunno if trucks are the same |
| engine close to operating temp, all plugs pulled, fuel and spark disabled and crank engine at WOT. |
| I agree with Brad, but I would look for at least 125 for a fairly fresh engine broke in. Is it an old carb version with a block fuel pump? run a gas can line to the pump and see if it will warm up, if it has been sitting for a long period the lifters may be colapsed till pressure gets to them, how is the pressure when you crank it?
| They all read 145-165 cold. |
| Good to go! |
| | #8 | |
It ran great when I got the truck, gas was at least 1.5 years old and it was 25 degrees. I know the engine can run good, I just wanted to check the compression, figure if I know it is good, it is a better selling point. | |
| Chevy 6.0 compression | chevy6-0 | Chevy Truck Forum | 5 | 04-27-2009 09:32 AM |
| Low Compression | rbmcveigh | Chevy Truck Forum | 10 | 03-17-2008 03:34 PM |
| newbie checking in w/ Q`s about engine swap | shadygrady | Chevy Truck Forum | 2 | 02-19-2007 05:23 PM |
| can you hear bad compression ? | xfrank12 | Dodge Truck Forum | 4 | 02-17-2007 10:08 AM |
| hello newbie checking in | jlc41712 | Introductions | 0 | 12-27-2006 11:14 PM |
