Old 01-21-2009, 09:39 AM   #1
brad4eva's Avatar
brad4eva will become famous soon enoughbrad4eva will become famous soon enough
350 motor
Hey guys, A while back i changed my oil in my blazer and come to find out about a month or two later it was empty... almost anyways idk what happen to the oil or anything what do i do now? would it be best just get a used motor from junk yard or have it rebuilt? It wil run and everything but when i slightly rev it up it will rattle sounds like bearings of some kind , samething going up a hill , just sounds like its about to lay down , need advice , rebuilt it or trash it and find a used motor? what about my piston walls would they be messed up or what? used motor around $ 500~ rebuild $ 280 ~
//B-rad
brad4eva is offline   Reply With Quote
Old 01-21-2009, 10:32 AM   #2
chevyman125's Avatar
chevyman125 is on a distinguished road
you could be getting pistion slap or conectioning rod bearing on your crank. there is problems with both rebuil and buying used doing a rebuil you could fix the problem and i new one could pop up if you don't check and change everything and if you buy a used one it could be f up unless you hear it run in a truck then it is better, i would do a compression test and see what it is and if it good then do a full rebuil new bearings new pistions the full deal then you know it is all new and nothing can go wrong. that is just what i would do
chevyman125 is offline   Reply With Quote
Old 01-21-2009, 10:57 AM   #3
brad4eva's Avatar
what about it using oil? it used alot of oil within the last few months, wat on that? i'm thinking about just fixing the problem and doing machine shop work and getting everything right , what u think?
//B-rad
Old 01-21-2009, 11:22 AM   #4
If you can rebuild it for $500 parts and labor do it it's dirt cheap! A mr goodwrench is about $1800 for a plain jane
Old 01-21-2009, 06:18 PM   #5
the using oil part you could be getting blow by, you could have a valve seal gone and oil is leaking down into your cylinder. thoes are the two things i could think of. but ya if you can rebuild it for $500 bucks do it up just make sure to check all your bearings lol my freind had so truble not checking the bearings rebuilt a motor and didn't check his crank bearings and put the motor back together and 10 miles later he had it back apart lol
Old 01-24-2009, 11:49 AM   #6
batty1214's Avatar
for just under 3000 you can get a 400 horse 350 long block from year one......(i havent heard how reliable the motors are, but the t.v show horsepower, and musclecar uses them, so Im guessing they are okay.) But, if you are going to rebuild, you could pull a head and look at the cylinder walls, and then decide wether to get a used and rebuild it...
batty1214 is online now   Reply With Quote
Old 01-25-2009, 12:26 AM   #7
heavychevy85's Avatar
heavychevy85 has a spectacular aura aboutheavychevy85 has a spectacular aura about
just rebuild her i am going to rebuild my 350 maybe in the next couple years cuz i plow and everything so thats what i will do you can buy the whole rebuild kits just about anywhere so get er done
heavychevy85 is offline   Reply With Quote
New Motor??? batty1214 Ford Truck Forum 7 12-08-2008 04:29 PM
302 motor liftedtrucks4me Ford Truck Forum 3 02-25-2008 09:34 AM
new motor smokensteve Chevy Truck Forum 3 12-02-2007 09:41 AM
All About Motor Oil Chevy808 Off-Topic 2 12-10-2006 07:15 PM
motor swap mmrcustoms Nissan Truck Forum 1 11-06-2005 07:18 PM
