| Senior Member Join Date: Sep 2008 Location: Southern MN
| Drilling hole in the firewall... Well I'm trying to find a spot to run some wires through for my foglights. I remember on my hondas there was always a couple of holes that were covered by rubber grommet/plugs. It looks like there's stuff all over on both sides of the fire wall and I don't want to hit something with my drill bit. Also is there a 12V source I can tap into from the fuse block underneath the dash? Thanks, Mike
__________________ 96' Silverado Z71 04' Honda VTX 1300 S |
| cut a hole in one of the gromits in the firewall just big enough for the wires to slide through. and yes there is a 12v wire get a test light and look for i think a yellow wire and make sure you put a inline fuze somewhere near the fuzebox.
| Use a medal cloths hang to fish your wires though the firewall it's saves a lot of trouble. |
| OK here is a tip i learned at the audio shop.get an old golf club with a metal hollow shaft, cut the head off, sharpen the end. now you can poke it thru a grommet, from outside, go inside, feed required wire into the shaft, pull out shaft, and the wire is there and the grommet close around the wire ![]()
| Only bad part is I don't see any grommets that I can poke through. Are they hidden or am I just that blind? -Mike
| how about next to the steering column?
| 98 S10 Where is rear axel fluid fill hole ? | STRAYDOG | Chevy Truck Forum | 8 | 10-14-2008 12:42 PM |
| weep hole | adrnmrnda | Chevy Truck Forum | 3 | 06-01-2008 06:48 PM |
| HELP-pin hole in gas tank | tims84k10 | Chevy Truck Forum | 1 | 11-13-2007 10:47 PM |
| Hole in the hood. How can i patch it up? | bubbas91lariat | Ford Truck Forum | 12 | 07-21-2007 02:48 PM |
| Carriles claims reward for hole-in-one at Irish Open (Yahoo! Australia & NZ News) | trucknews | Truck News (headlines) | 0 | 07-22-2004 09:30 AM |
