Old 02-04-2009, 06:28 AM   #1
stewartville is on a distinguished road
1998 Chevy Truck Fuel Gauge Trouble
I have a 1998 Chevy K1500 Ext Cab that had a loud fuel pump while at the same time the fuel gauge vibrated rapidly (needle actually looked blurry). Replaced it twice with NAPA assemblies, and never solved either problem. Replaced again with an AC Delco and solved noise and vibration but was rewarded with a new problem. Now fuel gauge is completely eradic. Sometimes its full sometimes its empty and it moves while going down the road. Finally I replaced the instrument cluster and the same problem still exists. Thanks, Ryan
stewartville is offline   Reply With Quote
Old 02-04-2009, 07:05 AM   #2
Kennyray's Avatar
Kennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud of
did you replace the sending unit when you relaced the pump
Kennyray is offline   Reply With Quote
Old 02-04-2009, 07:07 AM   #3
Welcome to the forum
Did you confirm a clean ground at the tank?
Old 02-04-2009, 10:08 AM   #4
^that is where my money is at^
Old 02-04-2009, 01:18 PM   #5
fuel gauge
Yes we replaced the entire unit. And we also have a good ground at the tank. Thanks
Old 02-05-2009, 12:48 AM   #6
Is this part of the recall years for dashes ? Might want to search the forum for old threads on that.
Old 02-05-2009, 09:43 AM   #7
stumpuller454's Avatar
Its either a bad wire ittermitantly contacting or a problem with the dash. an open circuit in the sense wire will read full on the dash. To varify get a instrument cluster diagram and check resistance of sending unit, i beleive its around 65 ohms for full tank, if you find it higher you have an open wire somewere to go find. I probly have a diagram in my 98 service manual, if you like i can look it up and tell you were to test it.
SUPERCHARGED 454 K2500 GMC!
Watch My Youtube Videos!!<<<
Old 02-05-2009, 05:23 PM   #8
Couple thoughts: How full is the tank when you are seeing these full scale swings ?
Makes a difference in trying to see where the prime error is from.
When stump says over 65 ohms you might not want to worry too much
about anything below 100 ohms as showing broken wire.
Unless you pull it from the truck, resistance will vary with how much fuel is in tank.
You get vibration while driving down road. If you are lucky enough to have
the needle stay in a wrong place when you pull over, try pounding the dash
before shutting it off. This would indicate a local problem.
May want to try that while driving too. Good luck.
I know my gauge would return to normal when stepping on brake,
this was because of wire drag below dash.
1998 chevy 1500 weird startup problem...fuel? stevenskins Chevy Truck Forum 4 05-22-2008 01:49 PM
Fuel Gauge and Oil Pressure Gauge problems landonh GMC Truck Forum 12 04-23-2008 10:26 PM
1998 chevy truck fuel pump regulator swflatt Chevy Truck Forum 2 01-04-2008 06:29 PM
1998 V6 chevy S10 fuel pressure regulator diagnosis STRAYDOG Chevy Truck Forum 0 10-21-2006 08:18 AM
2001 chevy 2500 Fuel gauge teampenner Chevy Truck Forum 10 08-15-2006 02:08 PM
