Results 1 to 7 of 7
Thread: 2000 K3500 PRNDL lights issue
    Feb 2009
    6
    I have a problem with the PRNDL lights. P & L light up when in gear but RND32 quit lighting up yesterday. Trans works fine (4L80-E). All other lights work fine. No blown fuses. Anybody ever see this before? Any suggestions? 2000 K3500 Crew 7.4L Auto 56K. Thanks, stftruck
    Dec 2007
    2,206
    can`t say i`ve seen that before in the OBS trucks, its pretty easy to remove the cluster and have a look at the lights back there, maybe some silly plastic peice broke and is covering the bulbs, got any picks of your truck?
    I know on the NBS trucks the PRNDL switch on the trans causes the lights in the dash not to work sometimes, most comonly anyways, but they are $$$$ to guess at this point.
    Gone.
    Feb 2009
    6
    2000 K3500 PRNDL Lights Issue
    Thanks, I already looked at the range selector. Plug for feed to cluster is clean inside & nothing broken. Looks like I need to check the cluster for anything obvious. Maybe I can test the lights & feed from range selector. I tried to attach a picture...we'll see if I succeeded.
    Attached Images Attached Images
    Dec 2007
    2,206
    SWEET truck! i WISH i had a crew cab, you`ve got some low miles! i`m at 60k myself, and trying to finish up this supercharger.....
    Gone.
    Feb 2009
    6
    Thanks! I bought it @ 14k about seven years ago. My first Chevy truck. I'm impressed with it. Real nice ride for a 3500!! With the 4:10's I only get 11-12.5 MPG. With or without a load. I can't see the expence of installing 3.73 gears. Just have to live with it.
    Dec 2007
    2,206
    yeah best i could get before tuning was that, but was getting 13-14 city this summer, my trucks alittle bit smaller though. and I`m sure I`ll be in the single digits this summer.....(:
    have you changed your factory muffler? biggest gains in mieage was from getting a catback system with my truck...
    Gone.
  7. #7
    Feb 2009
    6
    Everything is bone stock. I put on one size bigger tire when I changed out the orignals though. Barely any room up front to clear those. It had a Debut conversion added from the factory. Lucky for me it did not have those fiberglass flares all the way down the side they always seem to add. Just a set of real SS step tubes & they painted the factory flares white to match truck. Also one of those lift up soft tonnue covers.
  1. 99 GMC K3500 grill removal
    By dogsrme in forum GMC Truck Forum
    Last Post: 08-27-2007, 03:14 PM
  2. 2000 Silverado A/C issue
    By Lend-a-Fish in forum Chevy Truck Forum
    Last Post: 06-29-2007, 05:29 AM
  3. Brake problem on 1996 K3500
    By mjeltema in forum Chevy Truck Forum
    Last Post: 12-27-2006, 07:08 AM
  4. 1990 K3500 454 Turbo 400 problem
    By krandall in forum Chevy Truck Forum
    Last Post: 10-06-2006, 05:31 AM
  5. Trans Issue 2000 Silverado
    By 2000Chev in forum Chevy Truck Forum
    Last Post: 10-04-2005, 05:47 PM
