Old 02-10-2009, 06:51 PM   #1
MikeHulbert is on a distinguished road
Adding Leaf Springs
I have a 2004 1500 Z71. I am a professional fisherman, who travels a TON with big boat and LOTS of gear. My boat is 20 ft, and comes in around 3000 pounds, add a bed full of gear, clothes, etc...and the truck squats more than I would like. The boat hardly ever, like maybe 5 times, comes off my truck May-December.
Should I simply go to a dealership and explain that I want another leaf spring, add something simple that one of you might know about, look for something else???
What are you thoughts??? With spring right around the corner, I would like to get this done pretty quicky.
Thanks!
MikeHulbert is offline   Reply With Quote
Old 02-10-2009, 07:08 PM   #2
go buy yourself a set of overload springs. you will despise them the first time you dont have a load, but i promise you that no matter how much weight you put back there, she wont squat.
Old 02-10-2009, 07:09 PM   #3
Not so sure that hitting the dealership is going to be the best alternative, and this would probably not be a cost efective option.
Several ways to go about this, and you can either add a helper spring, air bags, or other type of load leveling device.
Your Z-71 has a block under the spring in the rear, so depending on how far your truck is being tasked, you can add that amount to the block. In other words, if you have a 3 inch block now, and you want toraise the ride heigth an inch, just replace the block with a 4 inch block. 4 inches is about the limit, but again, there are plenty of options.
An other option would be to just install some new rear leafs from a heavier duty truck. All of these trucks use a 64 inch spring, so they are interchangeable.
if you have a 1500 spring, then maybe a spring from a 2500 truck would work.
Old 02-10-2009, 07:10 PM   #4
batty1214's Avatar
you could look into a airbag setup. they work well, and you can get a set that you have to manually air up or down using your home compressor for fairly cheap, or go all the way and get the onboard air compressor. With the airbags, you don't sacrifice ride as much as some other methods, as you can adjust them for the load your carrying. This is only my opinion, but Its the way I would go.
Old 02-10-2009, 08:01 PM   #5
Any advice as to where I can get a pair from a 2500 or a 3500 so I can put them on my truck?
Or what brand of "over load" springs do you recommend?
I appreciate your help.
Hulbert
Old 02-10-2009, 08:08 PM   #6
go to camping world and get a set of air bags for it!
Old 02-10-2009, 09:15 PM   #7
wild bill's Avatar
wild bill is a name known to allwild bill is a name known to allwild bill is a name known to allwild bill is a name known to allwild bill is a name known to allwild bill is a name known to all
springs
if you go with timbren ses suspension enhancement boosters you get more bang for the buck ,and you can put them on your self .no maintenance required . Vehicle Suspension Kits - Timbren Suspension Enhancement Systems
wild bill is offline   Reply With Quote
Old 02-11-2009, 06:48 AM   #8
for 2500 and 3500 springs, check out some of the local junk yards. as for the overloads, there is a trailer place here in town that has them by the dozens. what happens is these people by them thinking that it will help, which they do, but they dont like the ride it gives you when you are unloaded. so they give them back and they sell them for dirt cheap. might check around for something like that.
Old 02-11-2009, 12:33 PM   #9
I use 2500 leafs under my old ford truck. These 64 inch springs are pretty easy to find. Some local junk yards will have them, but because of the year, they are still pretty new, and some yards will sell them for a little too much.
For the price of a few cold adult beverages, you can score some leafs at your local off road shop. Yup, many guys opt for completely new leafs leaving the old ones as good candidates for an upgrade.
Often these are thrown away or just set aside for a rainy day. There is not much desire for these springs other than replacements, and this market is slim.
You happen to be one of the guys that needs these and you can take full advantage if you can find some of these jewels.
You may offer to pay the shop for installing them and they wil strike a deal with you.
I often show up with a couple of large pizzas, or cold beverages, and ask for the scrap parts. The cooperation is unbeliaveable.
You can get some springs for a real good deal using this method.
No kidding, it works. Worst case, the shop will be able to help you with your situation, and this is still a win win deal.
Old 02-11-2009, 01:40 PM   #10
Erock80's Avatar
Erock80 will become famous soon enoughErock80 will become famous soon enough
Mike, I guess you're questions have pretty much been answered, so I'm not even sure if I should bother here. But, I tow a boat with my truck too, and didn't want' the "squat" so I just took the old "1500" leaf springs out - simple job really - and put in a nice set of new 2500 springs. That was it. Couldn't have been simpler, and no squat.
Erock80 is offline   Reply With Quote
Where to get factory replacement coil and leaf springs? ponie1992 GMC Truck Forum 11 06-19-2008 07:36 PM
Adding refrigerant, need oil? DeepDan General Truck Forum 9 05-20-2008 03:12 PM
update on squeaking leaf springs classicZ71 GMC Truck Forum 9 05-01-2008 06:18 AM
Annoying leaf springs classicZ71 GMC Truck Forum 2 03-24-2008 05:35 AM
94 ranger rear leaf springs lmm3466 Ford Truck Forum 0 07-13-2006 06:52 PM
