| | #11 |
| right, after the check engine light comes back on there may be a stored code again
| | #12 |
| i wonder if this could be an Idle Air Controller problem. |
| | #13 |
| Junior Member Join Date: Feb 2009
| Hello again, just thought I'd give an update here. I had the truck towed to a shop. Turned out the problem was the distributor. He changed a faulty coolant temperature switch and that got the truck starting by itself, but it died on him during a test drive. After he got it back to the shop, he started checking/wiggling wires. He found one that was grounded and changed it, but apparently that had no bearing on the problem. Then he shined some kind of light on the injectors to see if they were pulsing/spraying and found no pulse, lol. Apparently this made sense to him, cuz he ordered a new distributor for it and put it in and that seemed to do the trick. |
| | #14 |
| Good man. Glad you got it fixed. |
| | #15 |
| well when it acts up again, scan the computer, and check the the ecm temp sensor
| | #16 |
| in case you are wondering, there is a ignition control module in the distributor that controls the injectors. evidently, it was malfunctioning. |
| | #17 |
| OOPs guess i did not follow the thread correctly, Thanks for posting results, glad it's fixed
| Addition to "'93 won't start" | OskarPilot | Chevy Truck Forum | 6 | 12-05-2008 05:49 PM |
| Unusual "overnight" no start continues , Update still need help. | STRAYDOG | Chevy Truck Forum | 10 | 10-23-2007 09:32 PM |
| "99" 2500 Tranny Problem | 2500 guy | Chevy Truck Forum | 2 | 03-07-2007 10:22 PM |
| S10 Intermittent "overnight" no start continues ,need help from electrical Guru | STRAYDOG | Chevy Truck Forum | 11 | 11-09-2006 03:59 PM |
