| | #11 |
| Includes 8 radiator cap adapters for servicing most domestic and import vehicles i think mine has 2 and felt fortunate that i have that many. |
| | #12 |
| wow thats still a great deal i'm headng up there in the middle of march they are having a big sale |
| | #13 |
| if you are on their e-mail list they send out coupons and stuff, last one was 20% off
| | #14 |
| Senior Member Join Date: Jan 2008 Location: Manhattan,Kansas
| im sure you guys have this under control, but for Case, my trucks headgaskets ARE leaking for sure. the right is the worst. it is bad enough that there is water coming out the tail pipe on the right side(true duals) , let my truck idle to warm up after work and had a PUDDLE under the right exhaust tip ten minutes run time tops. the left was bone dry. cold day down to 25. but the point is the coolant is leaking into the cylinder but instead of the compression going into the cooling system it is also leaking down the block, but i can see my leak, so, like i said not much help. just input.
__________________ GOD BLESS CHRIS LEDOUX!!! |
| | #15 | |
| | #16 |
| Senior Member Join Date: Feb 2009 Location: Cody, Wyoming
| which carb would be best for a 350 in a 79 chevy pickup Last edited by silverChevy79; 03-03-2009 at 10:46 AM. Reason: mistake |
| | #17 |
| change your gaskets. look for leaks anywhere that the water runs. look for excesive coolant in the cylinders. watch for any type of leak and get good gaskets. i would suggest fel pro and use black RTV made by permatex. it works and if you have to work on the truck again then the sealant is easy to get off. |
| | #18 |
| a carb for the 79 double pumper or a rebuilt tricked out quadrajet |
| | #19 |
| Hey heavy was this a hijack?? ![]() so did you buy a tester?
| | #20 |
| no i didn't i am trying what is called headgasket sealer you mix and pour into ur radiator and hope it works you have to let it set for 24hrs so hope it works it was only 7 bucks i'll try this if it dosn't i'm going in |
| Tags |
| coolant |
| Changing Antifreeze. | gmctrucks | General Truck Forum | 7 | 10-10-2008 02:18 AM |
| 02 yukon | heavychevy85 | Chevy Truck Forum | 1 | 06-22-2008 01:40 PM |
| antifreeze going down ? | vanhal | Chevy Truck Forum | 8 | 01-07-2008 07:40 AM |
| 97 yukon for sale | 97yukon | Truck Classifieds | 0 | 07-29-2007 10:42 AM |
| GM red antifreeze question | ohio larry | Chevy Truck Forum | 7 | 03-25-2006 08:26 PM |
