Old 02-27-2009, 09:46 AM   #1
dunebound69 is on a distinguished road
1999 k2500 abs problem
On my 1999 k2500 with the 7.4 my abs is coming activating on dry pavement. Seems to do it more often on turning/braking combo. I have check brake fluid and power steering fluid. My scanner dose not seem to bring up anything for abs. Actron 9150. Any info would be wonderful. The truck has 170000 miles.
dunebound69 is offline   Reply With Quote
Old 02-27-2009, 09:48 AM   #2
03chevy's Avatar
to get codes from your abs system you need a abs scanner
Old 02-27-2009, 11:08 AM   #3
crabtruck's Avatar
One thing to keep in mind is that an ABS light can show activation (use), not just failure.
I would suggest inspecting the brakes to see that the basics are good.
ABS activates when it sees a mismatch for wheel speeds/braking apply.
You didn't mention speed this happened at. One thing that can cause
low speed (< 5mph) light is rusty sensor mounting area. Somewhere
in another thread I was trying to remember the test value of those.
I put it here only because I remember it right now. If you unplug
those front wheel sensors and spin the wheel by hand, you should get
about 350mV AC across its wires. If 200-350, too big a gap between
sensor and the reluctor ring may exist due to crud. Clean & retest.
Old 02-27-2009, 11:31 AM   #4
I is happening at low speed. IE at a stop light, turning into the driveway. ABS light comes on goes out. Front brakes have about 30k on them but don't look bad yet. I don't go through brakes to fast, I don't go from gas to break. It is legal to coast up to a stop. (The other half at the house kills a set every 15k, I don't even like to ride with her). Thanks for the tips I will look at them this weekend with any luck.
Old 02-27-2009, 01:33 PM   #5
If it hasn't been done lately, you may want to consider flushing the lines with new fluid and change the rubber hoses on the front, abs may be sensing sluggish fluid flow
Tags
abs
1999 B3000 Ignition Key Problem Polarbear Mazda Truck Forum 4 11-12-2008 01:15 AM
Strange starting problem 1999 F250 7.3L Kawboy Ford Truck Forum 14 07-28-2007 07:01 PM
1999 GMC Jimmy Ignition/Key Problem paperjam GMC Truck Forum 5 09-17-2006 10:11 AM
1995 K2500 ABS problem shepard Chevy Truck Forum 1 06-14-2006 02:04 PM
93 k2500 4 X 4 with TBI problem slavio GMC Truck Forum 2 11-24-2005 07:27 AM
