Old 02-28-2009, 02:50 PM   #11
batty1214's Avatar
Originally Posted by leolkfrm View Post
jump the connector to the switch!
??????? how? It sounds like a good idea..... but, how do you propose?
Old 02-28-2009, 02:54 PM   #12
pull the connector down and use a piece of wire in place of the switch
Old 02-28-2009, 02:57 PM   #13
batty1214's Avatar
I about asked a dumb question, but it just clicked in my head on what you meant. so anyway, I'll try it monday and see what I find. have you got any other ideas where to look?
Old 02-28-2009, 03:00 PM   #14
looks like crab gave you a pretty good checklist already! have you been through it yet?
Old 02-28-2009, 03:04 PM   #15
batty1214's Avatar
no, I started on it at 1:00 friday afternoon and the work day ended at 2:30, and I replaced a cracked splitter board at the back end hopping it was the deal.... they asked me to come in and finish it, but the mine operations ticked me off so I am gonna let them pile into extended cab pickups until monday, cause me and the wife just closed on a house and uh........I have alot of excuses that I have, not to help the guys that know nothing, but tell me how to do my job.
I just am looking for a good place to start on monday, so I don't waste too much time on it
Old 02-28-2009, 04:12 PM   #16
crabtruck's Avatar
Don't screw with the brake switch - it's gold. See "A".
Hot at high stop means you don't even have to check "B" or "C"
You say you have hot at both sides "D" so that leaves "E" "F" & "G"
( Not an excuse to say E F n G )
This pic is the same as the list I gave above.
Note trailer and hi-stop are on "B" fuse not "D" fuse, so are seperate.
Just track wire from "D" fuse.
(of course you checked the common bulb ground right?)
Old 02-28-2009, 07:49 PM   #17
batty1214's Avatar
the only grounds I could find is the one coming out of the main harness a little ways up the line..... is there another one in there somewhere?
Old 02-28-2009, 07:59 PM   #18
crabtruck's Avatar
Tail/stops etc share a ground so easiest is pull the bulb
and check the socket connects to ground.
Unneeded check if other half of bulbs there are working.
See how they all share that ground at very bottom of pic ?
Should be one good is all good, unless by an incredible freak occurence,
both stops lost their grounds at the same time seperate places.
You should also check that the right bulbs are installed.
Not likely problem, but you will kick yourself if that's it.
Old 02-28-2009, 09:49 PM   #19
batty1214's Avatar
well, backup,marker,turn signal all work. just not the brakes
Old 02-28-2009, 10:23 PM   #20
crabtruck's Avatar
Good then check for hot at "E" as it goes through that underhood fuse block thing. Most likely a pulled wire. Ground seems to be ok.
Tags
brake light
94 Z71 brake light comes on barbermike34 Chevy Truck Forum 2 12-24-2008 07:08 PM
Just bought a new brake master cylinder and its not working help!! 89se-5 Mazda Truck Forum 8 12-10-2008 11:52 AM
Truck Brake Lights working, Trailer NOT lakelaurashawn Chevy Truck Forum 11 07-16-2008 08:13 PM
brake light smokensteve Chevy Truck Forum 3 05-12-2007 05:33 AM
Dome light not working correctly mochester Toyota Truck Forum 1 05-28-2006 12:18 AM
