| Junior Member Join Date: Feb 2009
| any one have any ideas what may cause trouble code 45 0n a 1988 chevy 1500, with a 350 engine. i just put this engine in about a week ago. i read where it mean rich exhaust but didn't say what might cause it. thanks |
| Left bank O2 sensor error (rich condition indicated) could be caused by an O2 sensor. |
| Running rich can be caused by sticking injectors or defective fuel pressure regulator. Or as Brad says may just be bad oxygen sensor. If it has more than 60000mls on it I would replace it anyway, clear the code and see if it comes back. |
| Could also be from a low vac/leak condition (or a bad MAP thinking so, if there). ECT could fool ECM also. Suggest check for plugs being on tight and vac leak before anything expensive. Check fuse for the o2 if heated kind. |
| if you have someone with a scanner it may shed more light on the problem
| Tags |
| dtcs |
| code 42 | hi-perfcam | Chevy Truck Forum | 0 | 11-03-2008 01:07 PM |
| 2006 Ram trouble code? | moonpie41 | Dodge Truck Forum | 3 | 07-01-2008 01:04 AM |
| Trouble Code PO455 | cajunwoodrick | GMC Truck Forum | 10 | 07-05-2007 09:09 PM |
| code 41 TPS help! | ray299 | Toyota Truck Forum | 3 | 12-01-2006 03:37 PM |
| Trouble code fix | pinofire | Chevy Truck Forum | 1 | 01-06-2006 08:58 AM |
