| Full Member Join Date: Aug 2008 Location: north/east wyoming
| wont start when cold I have a 2000 silvarado that wont start in the cold. zero or below it wont start unless it is plugged in.obve zero it will start butjumps up and down on rpm 2000 rpm to almost dying and then back up again.spitts and sputters for a few then runs good. if it is warm out no troubles.any helpwill be nice |
| diesel or gas? Im assuming diesel. and, thats farily normal if it is. |
| what engine ? shd |
| Put it on a scanner, check the temp sensor
| Temp sensor would cause it to blow black smoke and die once it warmed up ( assuming its a gas motor)
| sorry about that it has a 4.8 gas. no smoke when you start it |
| TS will also cause a not start under 40 degrees, depending on the reading
| I will try that thak you |
| wont start when cold | lost in wyoming | Dodge Truck Forum | 10 | 09-16-2008 08:26 AM |
| 7.3L hard start when cold | wmiller | Ford Truck Forum | 9 | 06-02-2007 07:31 PM |
| 2002 1500 wont start in the cold | bigdog101197 | Dodge Truck Forum | 1 | 02-05-2007 04:22 PM |
| 98 S-10 Cold start problems | 1935ford | Chevy Truck Forum | 2 | 01-17-2007 01:58 PM |
| Clacking on Cold Start | mattymax | Nissan Truck Forum | 6 | 01-02-2007 06:29 PM |
