| Full Member Join Date: Nov 2008 Location: New York
| I have a 1989 chevy c1500 pick up, 2wheel drive 305 engine with 160000 miles on the truck, original transmission/ engine.The other day I was driving and my gears slipped, then went back to normal (automatic tranny btw). Then yesterday I was driving they did it again then my truck was stuck in first gear. The truck revs up high when I drive it and only moves when I put it into low gear or reverse and can only go about 15-20 mph when driving. It doesnt work in drive, over drive or second. I need to know how I would figure out the model number of the transmission for when Im lookin at the chiltons manual and I also need to know what I can try to do to fix it before spending alot of money buying a new transmission. Could it be the modulator or somethin like that or do you think the whole transmission is gone. |
| 700R that's a lot of miles on any trans. |
| You think I am going to have to replace it, or do you think it could be a modulator or somethin |
| 160K for a 700R4 is good mileage. I bet its a rebuild. Probally needs it anyways with 160K on it.
| sounds like it's time for new clutches and steels. if you can pull the trans yourself, a shop can rebuild it fairly cheap ($300-$600).
| are you sure it isn't a turbo 400 ? and yes could be the modulator . shd |
| My guess is a 700r4 since he says its a 1500. Oh yeah, 160K miles is absolutley awesome for 4l60e or 700r4. I'd says its slipping clutches from wear. I don't believe 700r4 has a modulator as some reminded me today. Also a vac modulator just decides shift points and I would not think it would cause a slip. |
| This guy hasn't been back in awhile, so he may have given up on it. |
| Okay I need help asap. | smilexelectric | Chevy Truck Forum | 14 | 02-04-2009 11:28 AM |
| Need Help ASAP with 85 C10 wiring problem's | chevyracer8262 | Chevy Truck Forum | 6 | 09-30-2008 08:00 AM |
| Stuck valve need help ASAP | 1989gmcsonoma | GMC Truck Forum | 6 | 08-24-2008 01:37 PM |
| science help asap | 72'CaminoKid | Off-Topic | 20 | 11-19-2007 04:33 PM |
| I need help Transmission ASAP | bevansbc | Chevy Truck Forum | 3 | 02-01-2006 09:13 AM |
