Old 04-13-2009, 03:23 PM   #21
Oriley is on a distinguished road
That small bolt that locks the long pin in place. I guess once I get the pin out I slide the axle in so the C-clamp will come off then I can pull the axle.
Oriley is offline   Reply With Quote
Old 04-13-2009, 03:24 PM   #22
It's a 8.5" differential if that matters.
Old 04-13-2009, 11:51 PM   #23
Hopefully you have figured this out already. Yes you will have to slightly move the axle in towards the diff to gain enough clearance to remove the "C" clip. If you are fortunate to have a cross pin that has enough clearance (pretty sure you dont) to allow the axle to be moved in far enough, then you dont actually have to remove the cross pin. Since I am 99.9% sure that you have to remove the cross pin, just make sure that the spider gears dont scare you when they pop out. After all of this the axles can be pushed in far enough to remove the clips. A telescopic magnet works soooooo well here, but a magnetic screwdriver or some mechanics picks can also work.
Dont have a magnetic scredriver? Lay it on the alternator when the engine is running, and it will magnetize the driver long enough to perform the job.
Once the clips are out, remove the axles and you are in like Flynn.
Be sure not to mixx up the axles. For some reason they get a little fussy about going in the opposite way. Seems that the splines twist and take a "set". Reversing this has usually turned into a broken axle for me. Just to be safe, leep them on the same side.
Old 04-15-2009, 12:01 PM   #24
Success
Went and bought a 5/16 six point socket and the bolt came right out.
I only had to remove one axle so all the gears remained in place. Only problem I had was getting the seal in, guess I should have bought the installer tool. I had to resort to a bigger hammer.
After doing it once I find it's a very simple job, nothing to it. Geezz....hope I put that 'C' clip back in.
Checked this morning and no leaks!
Thanks guys.
Tags
axle seals, axles
95 1/2 ton axle seals brittle Chevy Truck Forum 11 03-17-2009 01:52 PM
1990 Chev 4x4 1500 H Front Axle rampage Chevy Truck Forum 5 01-01-2009 07:04 PM
3/4 ton rear axle see error GMC Truck Forum 4 12-21-2008 07:25 PM
F350 Rear Axle I.D. otrman Ford Truck Forum 3 11-15-2006 06:09 PM
rear axle on 99' ranger nickelbn1 Ford Truck Forum 2 08-01-2006 11:03 AM
