Old 03-14-2009, 09:39 AM   #1
Elbow36 is on a distinguished road
4 speed manual, to nv3500 swap
Hey folks. I'm new to the site and I'm seeking some advise on a tranny swap. I have a 1989 Chevy K1500. It has a 4 speed manual bolted to a tbi 350. This is a standard cab with a 3" body lift. I want to swap out the 4 speed for a Getrag NV3500. The 4 speed dosen't have OD, it's more like a 3 speed w/a very low granny 1st gear, and it seems like its robbing a lot of power from the motor. I'm hoping someone has done this swap before and can help me out. From what i hear these trannys use the same transfer case, slave cylinder, and drive shafts. I don't think I want to do the swap if it's going to be a very involved one. If i have to change the clutch and flywheel, it's no biggie. Any info you folks might have would be greatly appreciated, Thanks a lot.
-Elliot
Elbow36 is offline   Reply With Quote
Old 03-14-2009, 10:30 PM   #2
moparmuscle will become famous soon enoughmoparmuscle will become famous soon enough
Direct bolt in.
moparmuscle is offline   Reply With Quote
Old 03-16-2009, 10:24 AM   #3
Wow, that sounds too good to be true, lol. Can I use the same clutch, flywheel and starter too? I might get out of this easier than I anticipated.
Old 03-16-2009, 05:36 PM   #4
Same clutch, same flywheel, same slave, same starter. Easy bolt in. Assuming it came from a 4wd chevy.
Old 03-16-2009, 06:30 PM   #5
Awesome. Thanks a bunch. I'm going to try and track one of these down this weekend.
Old 03-21-2009, 06:53 AM   #6
No luck finding a tranny for the swap yet. Does anyone know how much torque these nv3500's can handle? I might be putting a built 350 in front of it in the near future.
Old 03-22-2009, 07:51 AM   #7
I was under the truck taking a look at things that may need replaced during the swap. I noticed how massive the output shaft on my transfer case is. Does any body know if i have to remove the torsion bars and torsion bar cross member to remove the transfer case and tranny?
Old 03-22-2009, 12:17 PM   #8
No. Just remove the trans mount and the crossmember that it rests on.
Old 03-22-2009, 02:07 PM   #9
thanks mopar. I'm waiting to hear back from someone that has a nv3500 for sale. I'm definitely doing to do this swap soon. The knuckle head that had this truck before me changed the rear gear ratio to 2.73's and left the fronts at 3.42. Thank goodness he unplugged the transfer case and the actuator...So a rear end gear swap is next. With 3.42's and a .73 5th gear, I should see a 700rpm drop at highway speeds compared to the 2.73's and a 1.1 4th gear. I'm guessing it will boogie around alot better too.
Old 03-24-2009, 08:50 AM   #10
silverChevy79's Avatar
silverChevy79 is on a distinguished road
is the NV3500 a 5 speed manual? im trying to find a way to put in a 5 speed in my 79. not to big on trannies.
silverChevy79 is offline   Reply With Quote
Swap 4l60e to 5 speed brad4eva Chevy Truck Forum 9 05-16-2008 02:35 PM
Ford manual trans swap Ford4x4man Ford Truck Forum 7 01-27-2008 08:25 AM
Automatic-to-manual tranny swap...? westboundchevy Chevy Truck Forum 13 02-12-2007 12:33 PM
3 speed automatic to 5 speed manual help torino Ford Truck Forum 12 02-25-2006 06:17 PM
Speed Channel Truck Stop: Todd Bodine Takes an RC Break (Speed TV) trucknews Truck News (headlines) 0 09-01-2005 09:30 AM
