| Full Member Join Date: Oct 2008
| Hey gang,I've got my dually running good(new gas tank,pump, and distributor) I went to flush the engine out to put in fresh antifreeze...anyway the upper radiator hose wouldn't warm up.......the pump is working....does that sound like a bad thermosthat that's not opening up to let the coolant out of the engine? Also , I was going to install a flushing T (prestone brand).......the heater hoses from the firewall go to the top of the engine and the other goes to the radiator(not the water pump-as stated on the flush kit).....the hose to the engine is the inlet,,,right ? Thanks for your insight...Quad |
| Banned Join Date: Nov 2008
| Sounds like air bubbles, did you bleed the system? |
| ^^ I agree it sounds like air, how long did you let it warm up? is there a bleed screw on the top of the t-stat housing?
| I let it warm at least 1/2 hour maybe a little more.....I dont recall any bleed valve |
| Senior Member Join Date: Mar 2009 Location: New York State
| I thought if there's air in the cooling system, the engine will OVERheat, not UNDERheat...... until it's bled or circulates for awhile. I changed the stat on my Trans Am recently (from a 195 to a 160). I lost a lot of fluid in the process. When I started it up for the first time after the change and fluid refill, it warmed up to about 230 before I shut it off. Stock temperature stays around 205 -210. It continued to do so until I bled the system. I simply opened a line right underneath the I/M with engine running. That cured it. To me, it sounds like your stat is stuck OPEN.
__________________ Bored? Check out Project: Wreck. - The NonGoggleGuy - I'm unbelievable... believe me. |
| with the cap off how is the flow in the radiater??
| if there is air in the system, it might overheat, it might not. all depends on the mix and how low it really is. pop the radiator cap off and watch the flow like stated above and fill if necessary. |
| with the engine off, take the cap off and squeeze the hose, can you see the coolant moving?
| Tags |
| coolant |
| DIY ATF Flush? | z07 | General Truck Forum | 3 | 08-12-2008 02:27 PM |
| coolant system flush???? | 72'CaminoKid | General Truck Forum | 1 | 04-20-2008 03:32 PM |
| radiator flush turns into replacement | mudseeker | GMC Truck Forum | 5 | 01-30-2007 06:28 PM |
| Coolant Flush Problems | SMarlin40CL | GMC Truck Forum | 5 | 05-05-2006 12:24 PM |
| Don't flush truck wash s Agriculture business is suited for nearby feedlots (Greeley Tribune Online) | trucknews | Truck News (headlines) | 0 | 12-15-2004 01:30 AM |
