Results 1 to 6 of 6
Thread: 1998 1500 chevy starting problem-popping p1626 code?
    Feb 2009
    3
    Need help fellas.....
    Have replaced spider injector,fuel pump, newly programmed computer, etc on this 98 silverado 2wd with 350 v8.....the security light stays on constant but will not run on its own but will if you spray it with carb cleaner
    tried turning the key on and waiting for 10 minutes to reset code....same prob
    scanner states the p1626 code and that the security system not linking same password to the VTD??
    ANY SERIOUS IDEAS ON HOW TO FIX OR TO GO ABOUT BYPASSING THE SECURITY SYSTEM?
    Thanks
    Mar 2008
    N.Y.
    10,865
    Blog Entries
    1
    Welcome to the forum
    Who programmed the computer?? and is it a stock program? are you using a scanner or a code reader?
    Feb 2009
    3
    thanks for responding
    the local junkyard programmed the stock computer...they coded it to match the vin#,etc....and we are using a snap on scan tool
    Platinum Member
    Feb 2006
    michigan
    8,677
    does the key have a chip on it? try a different key and see if the problem changes.
    <----just your average 5.3
    Mar 2008
    N.Y.
    10,865
    Blog Entries
    1
    I remenber posting the reset process somewhere, no time now I'll look later.
    Feb 2009
    3
    ok thanks....to the other person asking about the keys....there is no chip with the keys i have...i wondered the same logic....but thanks for the suggestion i really appreciate it
  1. 1998 chevy 1500 idle problem
    By 1st time chevy in forum Chevy Truck Forum
    Last Post: 01-28-2009, 06:32 PM
  2. 1988 chevy g-20 van starting problem
    By blackls6 in forum Chevy Truck Forum
    Last Post: 08-02-2008, 05:14 AM
  3. 1998 chevy 1500 weird startup problem...fuel?
    By stevenskins in forum Chevy Truck Forum
    Last Post: 05-22-2008, 01:49 PM
  4. Code 42-Chevy 1500
    By rockitman in forum Chevy Truck Forum
    Last Post: 06-01-2006, 06:30 PM
  5. 99 Chevy starting problem
    By chevyz71 in forum Chevy Truck Forum
    Last Post: 01-24-2006, 07:27 AM
