| Full Member Join Date: Jan 2008
| need help , blower relay im having trouble finding relay for my blower , hvac , i have a 04 silverado 3/4 ton 4x4, none of the relays are marked hvac or blower , can any of u guys help |
| is this why?? Subject: HVAC Blower Motor Runs After Vehicle is Turned Off Model: 2002-2004 Chevrolet Avalanche, Silverado, Suburban, Tahoe, TrailBlazer 2002-2004 GMC Envoy, Sierra, Yukon with Manual Control HVAC Condition Some customers may comment that the HVAC blower motor continues to run after the vehicle has been turned off. Description The source of the customer complaint may be a stuck HVAC blower motor relay or linear power module (LPM). Procedure If the vehicle’s HVAC blower motor circuit uses a relay, the relay may stick in the "on" position. When the HVAC blower relay has been energized, the contacts may "micro-weld’ together. After this occurs, the HVAC blower motor motor may not respond to the HVAC control commands. For vehicles that use a LPM, the root cause is an internal failure within LPM. In the situation where either the relay or LPM may be the source of the complaint, the failed part must be replaced. After component replacement, confirm that the customer’s concern has been corrected
| http://www.extendedgmwarranty.com/ow...-Silverado.pdf here is the complete book, I think the electrical sec will help you
| yeah thats what happened my blower wouldnt stop running and now it doesnt blow at all i have my owners manual but i cant find relay even in book not even sure what an LPM is |
| i believe it is in the under hood box, engine side in the middle, should show on the back of the cover
| i appreciate all the help but i cant find a relay that says blower or hvac just a.c. comp |
| i can't cut and paste the diagram in the book! it showed 1 listed as blower in the middle of the end with the relays. did you look under the cover??
| none of the relay's say blower or hvac would it possibly be incorporated in the resistor |
| Good info Leo. |
| Drawing I have shows it in the "blower Motor Resistor Assm" Some have the impression that the newer parts make the blower spin a bit faster on all speeds. Just a note. ![]() |
| 4wd relay | my83432 | Chevy Truck Forum | 1 | 06-10-2008 03:26 PM |
| Need help with Fuel Pump Relay | falcon4life | Toyota Truck Forum | 6 | 04-29-2008 10:33 AM |
| 2001 4x4 A/C Relay failure? | mcarriker | Chevy Truck Forum | 6 | 06-21-2007 04:25 PM |
| Add another fuse for new headlight relay? | Fortyfied | GMC Truck Forum | 3 | 04-06-2007 05:25 PM |
| Stuck Relay!!!! | twanger1994 | Toyota Truck Forum | 7 | 01-23-2007 07:38 PM |
