| Full Member Join Date: Jan 2009 Location: Hermiston Oregon
| rear axle swap I have a 85 GMC 2wd 10 bolt 3.08 and I found a rear out of a 72 2wd with I think a 12 bolt with 3.45? and a posi will this drop right in? what style posi would this be? its a stock gm posi so a cluch or cone style? will my backing plates bolt on the 12 bolt or do I need to buy new brakes... mine have about 200 miles on them. I can pick this rear up for 75 bucks so even if it wont fit I can get my cash back just for the posi if this wont fit what years use the same axle I know the 88 up the springs are set out wider Thanks |
| hmm not sure if 72 will fit under 85 or not. anything 73-87 will fit though. and not sure but 72 and prior all used dana rearends (i believe...)
| Full Member Join Date: Feb 2009
| I think the 72 is set up for the coil spring rear so you would need to cut off mounts, weld on new ones. That is no big deal though. The bold pattern could be different at the hub. When all else fails use a tape measure. The other thing is the u-joint. |
| | #4 | |
Good luck! GMC | |
| the 2wd rearend is set up with trailering arms and coil springs like mrjohnwayne said |
| As Lifted and Johnwayne said, those are coil spring trucks as standard equipment, but I have also seen them in leaf spring suspension. I had a 64 GMC that was leaf, and a neighbor had a 72 that was leaf. We thought we were special because everyone else had coils. |
| Tags |
| axles, rear end |
| Solid axle swap | HIUPCHEVY11 | Chevy Truck Forum | 16 | 11-19-2009 08:38 PM |
| axle swap | ekacpuc | Chevy Truck Forum | 11 | 03-31-2009 07:29 PM |
| 3/4 ton rear axle | see error | GMC Truck Forum | 4 | 12-21-2008 07:25 PM |
| Axle swap | goldengoat2 | Chevy Truck Forum | 7 | 05-12-2007 07:47 PM |
| 96 f250 axle swap | nickm79 | Ford Truck Forum | 0 | 12-16-2006 10:55 PM |
