| Full Member Join Date: Mar 2009
| Error Code P0303 Cylinder 3 Misfire I have been trying to get my 1998 Chevy C1500 Ext cab truck to pass Texas Vehicle Inspection; however, I am getting a P0303 Error code. The error code is a "Cylinder 3 Misfire". I bought this truck from a private seller that had used it for his irrigation business. The truck had 166000 miles on it when I bought it and I only wanted to use is as a work truck that I would just haul supplies for home repair. I was getting another error code before; however, I fixed that by replacing the Bank 1 Sensor 2 Oxygen sensor. After I replaced the spark plugs, checked the wires (they looked newer) and cleared the code. I started up the truck and the "service engine light will come one. The "Service Engine Soon" light will come on for a few trips and then go off again for a few trips. Any help would be appreciated. |
| pull the injector harness off the upper intake or find the fuse for them. next, do a compression, spark and fuel pressure test. might want to find a scan tool and do an injector balance test too. also check the cap/rotor and swap out the spark plug wire to see if the code follows the wire.
| Is there a quick way to test the distributor cables? I have a digital multimeter that I can use to test the cables if I need too. I have heard that I should get an infinite reading if the cables are good. What do you think? I was also advised to do a spark test. How would I do that? |
| spray the wires with water and see if they arc, if so change them
| | #5 | |
| Turbo Cool-down Timer Throws Error Codes | Russ Weaver | Chevy Truck Forum | 5 | 06-22-2008 07:59 PM |
| 1996 5.0 vortec 300 misfire code | dwill80 | Chevy Truck Forum | 1 | 04-28-2008 05:03 PM |
| Engine misfire detected engine code HELP | Airforce wrench | Chevy Truck Forum | 2 | 02-21-2008 08:13 PM |
| Multiple Cylinder misfire | buttaluv | GMC Truck Forum | 4 | 01-17-2008 08:03 AM |
| No error on Newbury St.: A-Rod saves boy from truck (Boston Globe) | trucknews | Truck News (headlines) | 0 | 04-15-2005 01:30 AM |
