Old 04-08-2009, 03:58 PM   #1
BIGBLAINE is on a distinguished road
Another fuel gauge problem!
I am new here! Hello all. I have read all the posts and really feel hesatent to post another gauge problem! But i have a 1990 silverado 2500, 5.7L engine. The fuel gauge read 1/4 when i got the truck used. I put in a new sending unit and still tops off at 1/4 tank on gauge. Now when the fuel is at 1/4 tank the gas gauge will move as i turn corners, but above that fuel level its pretty much stable! Im not sure if theres somthing stopping the float or its somthing behind the dash. But i did see the gauge go to full when i unplugged the sender. So if that helps. Is there somthing in the tank that could seriously ubstruct the float? Maybe theres a regulator for dash gauge? Im not sure. But i thank you for your time.
BIGBLAINE is offline   Reply With Quote
Old 04-09-2009, 03:09 AM   #2
Welcome to the forum BIGBLAINE.
New sender makes this more interesting.
Showing full when unplugged is good news
in that it shows you do not have a ground short
in the wire going to gauge.
Try unplugging the sender again at tank, and
shorting that wire that goes to gauge to ground.
That should give you a dash read of empty.
Last test of the gauge end of things would be
to unplug the sender and ground the gauge wire
from dash to ground through a 90 (or 100) ohm resistor.
If you don't have one, places like radio shack sell
them for less than $1. Use a 1/2W not 1/4W if
possible because it's easier to handle and less
likely to break. This acts like the sender would
if there was a full tank of gas and gauge should
read full.
If you do not get grounding=empty and also
ground-thru-resistor=full, then the gauge may be bad.
Believe that truck uses a 2 coil gauge which means
it would not be effected by system or battery voltage.
Should read right regardless.
If the problem persists, it is sender/tank specific.
Do you have the right sender for this tank,
not just this truck ? Some tanks are shaped differently
at the bottom causing the sender to sit higher.
If you swapped the identical part to old one,
did it ever read right on old one? Does the gauge
read lower than 1/4 tank ever from fuel level,
not just shaking truck or making turns ?
Hope some of this gives you something to go on.
Good luck.
Old 04-09-2009, 12:34 PM   #3
silverhairdeere's Avatar
read full.
Good luck.
man this man is good , is he the chuck of truck form , hope he doesn't flash on me .
shd
Old 04-10-2009, 12:08 AM   #4
hope he doesn't flash on me . shd
I have absolutely NO idea what that means !
So...
A) Thanks dude.
or
B) I'll get ya for that.
Whichever is more appropriate.
Old 04-10-2009, 09:57 PM   #5
Well the stock sender did the same thing, The new sender is exact for the 34 gallon tank i have. I am at a loss. The resistor trick does work like you said, but still gauge goes up to 1/4 than stops until gas is down to 1/4 or less! I am leaning toward tank issue.
Old 04-11-2009, 12:19 AM   #6
Stop leaning, you're making progress by process of elimination.
Pull the sender from tank and operate it by hand,
grounding required of course. Avoid sparking
Old 04-12-2009, 12:25 AM   #7
Is there a baffle that can interfere? In the gas tank.
Old 04-12-2009, 05:18 AM   #8
Not that I know of
Old 04-12-2009, 05:23 AM   #9
So...
A) Thanks dude.
or
sorry i thought you were a tv & movie nut like me (and you get a A+ in my book)
http://en.wikipedia.org/wiki/Chuck_(TV_series)
shd
Old 04-12-2009, 06:05 AM   #10
OK, so I guess I go with "A)"
Never managed to catch that show, saw the ads for it.
It's funny, my tv is ten times the size of my first tv,
and I watch it about ten times less.
Usually when I'm watching tv I also am reading a book.
Keeping up with most stuff for either is not that big a job.
Movies and comedy both are getting kinda pathetic
with lots of rehashes of old movies and jokes, and most
not as good as the original. Watched a 1958 movie
the other night and it was better done than most new stuff.
TV mostly makes me cranky cause I'm intellectually picky
when it comes to the work of folks claiming skill.
My wife tells me she likes about 8 different tv shows,
but I say they're all the same show, just the names change.
Basically, I'd prefer to watch something I haven't seen.
Thanks for the compliment even if I was slow on the uptake.
I get that way in my little bubble sometimes.
Tags
fuel gauge
1986 Chevy Truck Fuel Gauge problem. tripower428 Chevy Truck Forum 43 04-02-2009 11:36 PM
2003 Silverado fuel gauge problem jsl Chevy Truck Forum 11 01-31-2009 01:02 PM
97 gmc fuel gauge problem Clint805 GMC Truck Forum 1 08-18-2008 12:03 AM
Fuel Gauge and Oil Pressure Gauge problems landonh GMC Truck Forum 12 04-23-2008 10:26 PM
1981 C-10 Fuel Gauge problem DaleP1981 Chevy Truck Forum 2 10-20-2006 04:53 PM
