Old 04-16-2009, 11:03 AM   #1
silverChevy79's Avatar
silverChevy79 is on a distinguished road
Lockers?
k. 79 chevy half ton. i want to put in a locker. what should i get? i use the truck as a daily driver, climbing truck, mud truck and tow truck. pulled many trucks, car and a tractor out of mud. need some help please
silverChevy79 is offline   Reply With Quote
Old 04-16-2009, 11:28 AM   #2
hotrodpc's Avatar
Detroit Locker. Stumppuller has a thread running right now about one he intalled this week. Detroit locker has arrived!!!
Old 04-16-2009, 12:41 PM   #3
Another vote for the Detroit, however, this vote comes with some stipulations.
This stipulation is on the form of the axle you intend to use. I would not be installing this locking device in an axle that has "c" clips. 1/2 ton drivetrain might not be the best option. (this may not even pertain to this vehicle)
The full float 14B is as strong as nails, and is probably the only axle I would consider the locker in. See, if the locker engages on the street it can place quite a bit of strain on the axles, and small axles will pop under the load, especially if a trailer is being pulled. The locker wont be the problem, the axle shaft will.
spending money on a small axle might bring an early end to the axle, and this miht not be money better spent,.
Old 04-16-2009, 01:49 PM   #4
moparmuscle will become famous soon enoughmoparmuscle will become famous soon enough
What about the 14 bolt semi floating axle? These are c-clip axles. I have been thinking about a locker for this axle that is currently under my '94 1/2 ton 4x4 ex. cab. I believe these also had the g-80 gov lock in them. Don't know much about these.
moparmuscle is offline   Reply With Quote
Old 04-16-2009, 03:51 PM   #5
MORROWMUDDER's Avatar
MORROWMUDDER will become famous soon enoughMORROWMUDDER will become famous soon enough
i put a lock rite in mine, i use it as a daily driver/work truck/play toy, i pull trailers most of the week, plow snow in the winter, and go off roading at every chance. i chose it because it is what my cousin has in his trail rig, he has had the same one in for 10 years with no problem. any just my input.
MORROWMUDDER is offline   Reply With Quote
Old 04-17-2009, 02:26 AM   #6
I knew when I responded to this thread that you (MORROWMUDDER) would have to reply.
I believe that you are the excepion to the rule, and every rule has one.
I have yet to be so lucky.......
Old 04-17-2009, 08:35 AM   #7
hotrodpc's Avatar
Are you saying Lock Rights are weak 75?
Old 04-17-2009, 08:47 AM   #8
how much do lock rights run for Dana 44? 3.73 gears
Old 04-17-2009, 08:51 AM   #9
hotrodpc's Avatar
Lock Right does not matter on the gears since they go into an open carrier. It appears it would $271 to $321 depending on which Dana 44 you have at Rocky Road Outfitters. They are the least expensive I have found for these units. Lockright (Lock Right) lockers, Powertrax, best prices, lowest cost locker kits
Old 04-17-2009, 08:58 AM   #10
well thanks yall. its going to be awhile tho, have to get the engine rebuilt soon before it blows. ill keep that in mind. anyone know what the NV4500 transmissions came in?
Tags
differential, lockers
Differences in Axle lockers junior3382 4x4 trucks / off road 15 12-26-2008 07:34 PM
