| Full Member Join Date: Mar 2009 Location: Kresgeville, Pa.
| 4L80E Tow Mode I have an 2000 Silverado 2500 4X4 with a 4L80E in it. I was haveing tranny problems and a tranny guy I was referred to said it was a bad valve body. The truck has 164,000 on it. Anyway I replaced the valve body and all was good, truck shifted and drives great. So now I'm haulin a lot of firewood lately and when I push the button on the shifter to go into tow/haul mode nothing happins, no indication on the message board and no difference in shift patterns. The tow/haul mode worked before on the old valve body, anybody got a clue? Thanks, Marc |
| buzz, i have a 2000 model 2500 series obs, 2wd, it has the 350 motor and 4L80e transmission. I assumed all 2000 model transmissions were the same, but mine does not have tow/haul. when towing I have to shift it to 3rd so transmission will not shift into the 4th gear. Can you not do this with your transmission? |
| odd, the 00 silvy i had had a tow/haul but it was a 4l60e. you would think that with the bigger tranny, they would have the tow/haul mode. |
| Senior Member Join Date: Mar 2009 Location: New York State
| 1997 K3500 dually here... 4L80E... no haul switch.
__________________ Bored? Check out Project: Wreck. - The NonGoggleGuy - I'm unbelievable... believe me. |
| Yeah my truck is a mixed bag of tricks, it's not labeled as a HD truck but has all the options like tranny, powersteering, and oil coolers, hydro boost brakes, heavy susp, rubber interior flooring. Anyway it also has newer gen 6.0L. I think this truck has what was called Contractor's Package, the series before HD can out later that year but who knows. I know I connected all the wiring back up after the valve body job, I'm tryin to figure out the abbreviations on the fuse box panels, I guess it's an electrical problem sense it's a switch. I though it might be a common bug so I'd ask. I have not tryed drivin in 3rd, but I'll give it a shot with this weeks haul. Thanks Last edited by buzzcut; 04-21-2009 at 09:47 AM. Reason: Forgot something |
| Certainly give the manual selected 3rd a try until you get this issue resolved, so you don't do any damage to the trans itself. So this all worked fine before the valve body change? I am not real sure on this electrical stuff. It would certianly think it has something to do with the switch. Being the trans is controlled by the ECM, I am wondering if you may have to re program the ECM to the new valve body for all the functions to work properly. It would certainly be worth a try. Did you replace just he valve body or all the switches and solenoids too? |
| did you check the fuses and connection plugs?
| Yep, I would check the fuses. Someone may have grounded out a wire during installation. Although it should not have had power with the key off. I would check all fuses, connections and if of that is good, then maybe consider the reprogram. In the meantime I will see else I can find out about it. |
| Here is something I found on another forum. This is responses to from 2 guys and a 3rd guy said, yep thats your problem. The problem is in the switch there is small wires in there one has broke free. Its a common problem, There's an Orange wire that usually breaks down by where the shift lever goes into the steering column under that rubber boot. |
| Thanks a lot I will check this out today and report back. |
| Tags |
| tranny, transmission |
| Question on 4l80E | ceasefire49 | GMC Truck Forum | 20 | 07-28-2009 05:03 PM |
| 4L80E Question | bigben | Chevy Truck Forum | 1 | 02-05-2009 02:23 PM |
| '93 4L80E trans | JOHN JAY | Chevy Truck Forum | 1 | 01-05-2009 06:34 AM |
| 99 dodge ram 1500 won't shift into 4x4 mode | boyya | Dodge Truck Forum | 1 | 06-30-2008 07:00 PM |
| heater mode door 1995 gmc sierra | hq109 | GMC Truck Forum | 0 | 01-13-2008 04:24 PM |
