Old 05-07-2009, 08:48 AM   #1
Butch Jones is on a distinguished road
loss of power
im lossing power in my 2003 4.8 mainly when it gets hot
im thinking its the converters any suggestions
Butch Jones is offline   Reply With Quote
Old 05-07-2009, 09:21 AM   #2
is the SEL light on?? converter would be a good guess as to power failure. how many miles do you have on it??
Old 05-07-2009, 12:15 PM   #3
i just turned 100000 and there is no lights on
Old 05-07-2009, 03:40 PM   #4
any signs of hesitation or miss?? i know i am asking alot of question but am trying to rule out other possibilities for you before lots of money is spent chasing the tail. when was the last time you did a tune up??
Old 05-08-2009, 05:48 AM   #5
i just changed the plugs and wires
it has a slight hesitation when its hot
i have a cold air intake which i clean on a rgular basis
im also losing antifreeze somewhere i cant find any leaks when im towing its running really hot
Old 05-08-2009, 06:53 AM   #6
how much coolant are you losing?? could be an intake gasket leaking if you cant seem to locate a leak anywhere.
as for your hesitation, might be a great time to have it scanned. this should tell you any problems that the truck is encountering when up to operating temps. should also tell you if the cat is beginning to let loose.
Old 05-08-2009, 07:27 AM   #7
how much trouble is it to change the gasket
can i get a scan done anywhere
Old 05-08-2009, 07:39 AM   #8
when im towing i lose more but on average im losing about a quart every 2 weeks
Old 05-08-2009, 08:24 AM   #9
.ben is on a distinguished road
a quart every 2 weeks is too much its probably the intake gasket hopefully not the head gasket....
my truck was losing power when hot like yours and it turned out to be a bad fuel pump but yours sounds a bit differnt in symtoms....
.ben is offline   Reply With Quote
Old 05-08-2009, 10:39 AM   #10
You really need to do that pressure test that radiator shops do or if you have the kit go for it because you need to know exactly where it's leaking from.
Good luck! GMC
PS-Ask a auto parts store maybe they can loan you one.
Sudden loss of power RangerJ Ford Truck Forum 5 03-01-2009 03:45 PM
Power loss under load - fan clutch? Alternator? Kiasis Chevy Truck Forum 18 01-24-2009 10:08 PM
Intermittent loss of power '88 Sierra V-6 gaander GMC Truck Forum 5 06-16-2008 07:22 PM
loss of power on shift o3shortbed Chevy Truck Forum 2 01-24-2008 08:25 AM
96 GMC Suburban loss of power. Steven6456 GMC Truck Forum 3 01-15-2006 09:06 AM
