Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: 1996 Chevy K1500 Rear Axle - weight carrying capacity ?
  1. #11
    hotrodpc's Avatar
    Jul 2008
    Moore, OK
    7,277
    I would tend to lean more toward the RPO code in the glove box being correct. If the owners manual is SUGGESTING at gear ratio, that is probably the standard gear ratio, but there are several others available. In a 1500 I much doubt its the full float rear. This 14 bolt that I got recently is a semi float and has 4.10's. You may also look for a G80 RPO code in the glove box too. If it has the G80, and is still original, then its locking differential. Not one of the better ones, It will be the Eaton Gov Lock.
    85 Sierra Classic K1500
    85 Silverado K10
    84 Silverado C20
  2. #12
    May 2009
    9
    Hi Hotrodpc!
    The RPO code in the glove box does not have a G80 code indicated. All I can say right now is that it has plenty of power and handles a heavy load pretty well for a K1500. The glove box has a code of GT4, indicating 3.73 gear ratio.
  3. #13
    hotrodpc's Avatar
    Jul 2008
    Moore, OK
    7,277
    If that the case, then its an open differential. If keeping it stock and you need a CHEAP locker, get a Lock Right. I hear they are good for up to 350hp and medium duty stuff. If you want to go hi po and doing some rough stuff, then get a Detroit locker, about the best money can buy in most opinions. I am a bit jealous though. I like that 3.73 ratio. Not so high, not to low. I have a 4.10 and a 3.21. Both ends of spectrum, but nothing in between which is where I'd like to be. The 4.10 will be OK if I get an OD trans with it, so rather then spend money on a gear change, I think I'd be better off spending the funds on a used 700r4 and building it myself. I happen to be buying 3 transmissions this week, all are cores, a T350, 700r4 and a 4L60-E. Getting all for $75 ($25ea) so that ought to get me in biz where I want to be using the 700r4.
    85 Silverado K10
    84 Silverado C20
  4. #14
    May 2009
    9
    Axle ID Location
    Where exactly are the identification markings located on a 96 Chevy, 14 bolt axle?
    Thanks,
    Capn Bob
  5. #15
    Mar 2008
    N.Y.
    10,854
    Blog Entries
    1
    on a tag under a bolt
  6. #16
    May 2009
    9
    Thanks for all the replies, but Im still not sure what I have for a rear differential. Maybe I shouldnt worry about it, but Im carrying a slide-in camper that weighs a little over 3000 Lbs. It seems to handle the load fine with the suspension add-ons. I am just curious what the manufacturer of the axel rates it at as far as load bearing. Im hoping that you more knowledgeable can answer my
    1996 Chevy K1500 4X4 Short Box, 5.7 Liter VORTEC engine with automatic transmission (4l60e RPO code M30), Firestone Ride-Rite Air Bags, KYB MonoMax Shocks, Torklift Stable Loads, and E rated tires. The RPO code (GT4) says that the axle ratio is 3.73, with diamond shaped, 14 bolt differential cover. Im pretty sure that the differential is the semi-floating type. Marks cast into front lower side of differential case are as follows:
    Front Left A wagon wheel shaped symbol followed by CFD (or O, I cant quite tell), and below that is 9690N
    Front Right GM7
    VIN NO: 2GCEK19R2T1135464
    Thanks,
    Capn Bob
  7. #17
    May 2009
    9
    96 Chevy K1500 Rear Axle, again.
    Front Right GM7
    Thanks,
    Capn Bob
  8. #18
    Mar 2008
    N.Y.
    10,854
    Blog Entries
    1
    According to the OEM specs you are overloading the axle
    Dimensions & Capacity
    DetailsFuel Capacity 25.0 Wheel Base 117.5 inches Overall Length 194.5 inches Width 76.8 inches Height 70.4 inches Curb Weight 3775 lbs. Tires / Wheel Size P235/75R15 Rear Tires / Wheel Size - Turning Radius 39.8 Standard Axle Ratio 3.08 Maximum Ground Clearance 7.0 Maximum GVWR 6100 Maximum Towing 7500 Payload Base Capacity 2069 Head Room: Front 39.9 inches Head Room: Rear - Leg Room: Front 41.7 inches Leg Room: Rear - Shoulder Rm: Front 65.4 inches Shoulder Rm: Rear - EPA Passenger - EPA Trunk or Cargo - EPA Total Interior - Truck Bed Volume -
  9. #19
    May 2009
    9
    Hi leolkfrm, thanks for the reply.
  1. 3/4 ton rear axle
    By see error in forum GMC Truck Forum
    Last Post: 12-21-2008, 07:25 PM
  2. 67 chevy truck rear axle
    By weeble in forum Chevy Truck Forum
    Last Post: 09-02-2008, 06:43 PM
  3. Rear axle problem 98 Chevy
    By Rooster_86 in forum Chevy Truck Forum
    Last Post: 07-14-2008, 10:12 PM
  4. F350 Rear Axle I.D.
    By otrman in forum Ford Truck Forum
    Last Post: 11-15-2006, 06:09 PM
  5. rear axle on 99' ranger
    By nickelbn1 in forum Ford Truck Forum
    Last Post: 08-01-2006, 10:03 AM
