| Senior Member Join Date: Feb 2009 Location: Okauchee, WI
| slipping tranny My tranny will slip or not shift out of gear intermitently all of a sudden. Whenever it happens the speedometer will not work or will bounce around. If I stop the truck and shut it off for a couple seconds it seems to be fine, sometimes still stuck in first or second, sometimes not. I've had the truck over a year now with no tranny problems till now? Could this hopefully be something electrical like a sensor? Thanks.....Matt
__________________ '94 Chevy Silverado Z71 Xtra cab 4x4 350cid 4l60e auto |
| scan the codes and see whats going on.could be a speed sensor.is the mil light on? |
| The service engine light is not on, and I've never seen it come on. I checked the codes anyway and there were none.
| If it is possibly the speed sensor, which one is it? Is it the one on the back end of the transfer case kinda on the top with two wires?
| I just re checked the codes. Codes 12 and 72 are there. Anyone know what they are, I can't seem to find my book all of a sudden.
| Code 12 should be there cause I'm doing a test, and according to the world wide web code 72 is VSS signal circuit error. So would that be vehicle speed sensor? If that's it, and it the two wire one on the end of the t case I have an extra t case I could try switching the sensors.
| code 12 i think is system pass. 72 is speed sensor. {i dont have a book}i believe it is. |
| try the other sensor. that should fix your problem. |
| I just switched the sensors and went for a kwik test drive and all was good. Hopefully that was it. I didn't re check codes, but so far so good. Thanks again.....Matt ![]()
| no problem. hope that fixed it. you might want to reset your computer though. its keeping that code stored. clear the codes and drive on. |
| Overdrive slipping.... | HawgHunter | Chevy Truck Forum | 16 | 03-12-2009 08:09 PM |
| slipping rear end | Akkeith | GMC Truck Forum | 7 | 07-29-2008 07:39 PM |
| 02 Silverado Trany Slipping | Kevin Hod | Chevy Truck Forum | 14 | 07-29-2008 11:02 AM |
| Slipping | colbyj86 | GMC Truck Forum | 3 | 07-28-2007 06:18 PM |
| e40d was slipping | flyer181 | Ford Truck Forum | 3 | 01-13-2007 08:19 PM |
