| Front differential problems When I pulled out my front differential on my 03 1500hd, to get at my oil pan, I found a few issues. I am trying to figure out if and how I should deal with them. ![]() The driver side axle to cv joint attached to a nice shiny plate on the differential. On the passenger side I wasn't so lucky, the diff plate and axle/cv were rusted together and required a good beating to get apart. There appeared to be a little leak on that side of the diff also. The truck has no problem in 4wheel(other than an occasional service 4 wheel message that goes away with a restart), no noises, and no great loss of fluid. But with it all ripped out anyways, if I need to repair, I should do it now. Is rust in this area a big deal? Is there a way to fix these to mounting surfaces without replacement parts (surface rust and about 60%) TIA for the help |
| have any pics of the problems?
| Senior Member Join Date: Jun 2009 Location: waterloo IL
| dont worry about the rust they all do it as far as the leak if u havent noticed the leak on the ground then ur ok just keep an eye on the fluid level
__________________ |
| Tags |
| axle, front differential, rust |
| 99 chevy front differential seal | 99chevy-ARMYMAN | Chevy Truck Forum | 5 | 05-20-2009 07:37 PM |
| slack in front differential | gejandsons | GMC Truck Forum | 3 | 03-13-2009 01:59 PM |
| Front differential grinding 2001 s10 | toby345 | Chevy Truck Forum | 2 | 12-07-2008 07:40 AM |
| Front Differential Leak | Charlieb | GMC Truck Forum | 5 | 04-09-2008 11:45 AM |
| Front differential seals | mjeltema | Chevy Truck Forum | 3 | 08-20-2007 10:08 AM |
