| Full Member Join Date: Jun 2009 Location: Ft Worth
| 84 C10 w/ engine swap detent cable issue Hey, after dropping a '96 crate vortec 350 w/ a 700R4 trans in the '84 the detent cable(A/T) sticks out if I do not grandfather the accel. It will suck back in if I turn the truck off and back on. The combo came out of a 73 and had roughly 2000 miles before putting in the 84. Intake is unknown but 4bbl and quadrajunk! Everytime I try to get to highway speeds or run from the cops I have to slow to 45 shut the truck off and put in nuetral or pull over to the side
__________________ SuperTramp '77 '84 C10 Custom Deluxe 350 Vortec 5.7l 700R4 '03 Silverado CC 1500HD 4x4 6.0l Vortec |
| Maybe you should consider a differant vehicle. Not sure a 84 C10 has half a chance outrunning the cops even working correctly. Not sure I understand the problem anyway in this lingo. Maybe a better explanation I'd get it, but I forgot to take my smart pills this morning. Forgive me.
| did you forget the outer spring?
| no the spring is on there even if i try to force the cable back it will not go back until i turn the engine off. the accell cable and the detent(sometimes called the overdrive) cable are on the same bracket and i can "feel" it in the pedal as it gets stuck out in what i presume is the passing gear. I checked the cable where it enters the trans(replacing 2x in the process) the guy i bought the combo(engine and trans) stated that there was a shift kit in the trans and i do not know if that could possibly have anything to do with it...
| | #5 | |
__________________ SuperTramp '77 '84 C10 Custom Deluxe 350 Vortec 5.7l 700R4 '03 Silverado CC 1500HD 4x4 6.0l Vortec | |
| It`s odd that the cable will go back as soon as you turn the motor off. I know nothing about the 700R4 but fluid leak in the valve body? |
| isn't that the cable that is adjusted by stepping on the gas to the floor to adjust? you push it thru the bracket and the accelerator sets it
| | #8 | |
| Senior Member Join Date: Jun 2009 Location: waterloo IL
__________________ | |
| Maybe you should consider a differant vehicle. Not sure a 84 C10 has half a chance outrunning the cops even working correctly. HOTROD come on did u not see the super sleeper pizza truck link an 85 with a 355 700r4 and 373 posi would run just fine from the cops
| 92 into 89 Engine swap | cc2058 | GMC Truck Forum | 5 | 06-19-2008 02:48 PM |
| 95 chevy bucket seat cable issue | havoc918 | Chevy Truck Forum | 0 | 05-03-2008 09:08 PM |
| Engine Swap | TXGMC03 | GMC Truck Forum | 3 | 12-26-2007 12:40 PM |
| Engine swap | paulem55 | Chevy Truck Forum | 0 | 12-09-2006 08:33 PM |
| another engine start issue... | johnboytx | Chevy Truck Forum | 1 | 01-16-2006 05:07 PM |
