Old 06-27-2009, 04:46 PM   #1
zk6216 is on a distinguished road
Need major help issues on 93 s-10!
Dear Thread Readers I need expert advice fast,
Now here is the issue first off this is a 1993 Chevy S-10 4x2 with 4.3L V6
Ok here is the story ... You can turn the key over she will crank and crank hit the throttle a little somtimes to WOT and she will start she will run ok at 1500RPM but as soon as you let off she will bog down start to cut out or stall ... I can run her hard if i can get her moving and at stop signs stay on the throttle.
I checked the TPS for the 1.25 V it was under that and went up smoothly
Sometimes while driving while i am on the throttle the gas gauge will shoot up then at idel go down ? she will run fine on the pedal and on the highway even going around 5 to ten miles an hour as soon as i let off the gas she bogs down starts to cut out and die run a little then die i chcked the PCV valve and hoses... NO Codes ... except for a Detation sensor which i put in already ... and the temp gauge does not work but these codes have been on for like a year and a half ... HELP PLEASE!! ASAP NEED THIS ONE TO RUN THANK YOU
Zak
zk6216 is offline   Reply With Quote
Old 06-27-2009, 04:52 PM   #2
72'CaminoKid's Avatar
sounds like maybe she's havin trouble breathing.... no codes from the o2's? have you checked to make sure exhaust is free flowing and not clogged
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 06-27-2009, 05:53 PM   #3
FaselZ71's Avatar
Yeah a clogged cat or muffler sounds like the culprit to me in this case... No codes though thats a kicker... Although I do recall one time my younger brothers 89 S15 jimmy was running roughly the same as yours and everything checked out. No codes TPS seemed fine and everything but we changed the TPS just out of spite and it corrected itself so that maybe something you could try... Good luck with your dilema
Old 06-27-2009, 08:14 PM   #4
z07
z07's Avatar
I vote for IAC idle air controller.
The IAC is a throttle in miniature. It is supposed to be under the control of the comp and keep the motor supplied with just enough air to run while at idle when you're foot is off the gas.
Old 06-27-2009, 09:22 PM   #5
do you still have the knock sensor code present??
i'd rather be hunting
Old 06-27-2009, 09:52 PM   #6
rdhack's Avatar
rdhack has a spectacular aura aboutrdhack has a spectacular aura aboutrdhack has a spectacular aura about
I agree with z07. While I was reading I was thinking IAC valve then I seen z07 was thinking the same thing.
Remove that ****** and clean it with carb cleaner. Spray out the hole it screws into as well. It should be located passenger side rear of throttle body.
Throttle position sensor could be cleaned as well. It is located directly in front of the IAC about the middle of the throttle body on passenger side.
MY first truck was a FORD.......I've owned Chevy's ever since.
1995 K2500 4x4 5.7L Cheyenne
1991 T-10 Blazer 4.3L Tahoe Package
2000 Ford Taurus - Spouses
rdhack is offline   Reply With Quote
Old 06-28-2009, 07:22 AM   #7
z07 beat me to it. might also check for a vac leak as this will cause a rough idle and if a bad enough leak, possible stall.
Old 06-28-2009, 08:45 AM   #8
Dear Readers,
Thank you so much i am going to go try to clean the IAC , i have repalced it about two years ago.. now here is a kicker he sprayed his engine off about two weeks ago could that hurt anything? i mean being this long to act up? thanks for all your guys help i really apreciate it !
Z
Old 06-28-2009, 11:00 AM   #9
Ok thread readers here it is again... new fuel filter, cleaned IAC Checked Spark plug wires cap and wires, spark plugs are a little carbon up not to bad... THE TRUCK WILL NOT START if I DO NOT HIT THE ACCELERATOR PEDAL !!! IT will on Crank as soon as i hit the pedal boom it fires and i have to stay on it, Could it be an EGR Valve?? i mean help PLEASE!~!
Old 06-28-2009, 12:25 PM   #10
Sounds like a bad fuel pressure regulator to me. Pull the vacuum pipe off it and see if you can smell gas.
Tags
major help, s-10
Major Problem!!!! drich10 General Truck Forum 4 09-09-2008 10:34 PM
Major Updates at Truck Forum Admin Forum Help 57 07-25-2008 04:56 PM
Major Updates at Truck Forum Admin News / Announcements 0 07-21-2008 02:54 AM
98 350 needing major help boxerdog1015 Chevy Truck Forum 3 03-08-2008 09:56 PM
major shifter problems o3shortbed Chevy Truck Forum 0 02-08-2008 08:53 AM
