| Senior Member Join Date: Apr 2009 Location: Lorain
| Compression Question Hi guys, So I have a 81 Chevy k20 with a 350 4-bolt main and its blowing blue smoke. I know its my rings. Here are my compression results (dry only): *edit: I did this with a cold engine (not at operating temps) 1 - 120 2 - 100 3 - 95 4 - 100 5 - 85 (oil on plug) 6 - 95 7 - 95 8 - 95 So from your experiences how bad off am I? It's my mud truck, just wondering if I will get 8 more Friday's out of it.
__________________ 1981 Chevy K20 3/4 ton 4x4. 350 with th400 trans. 33x12.5x16 Super Swamper SSR. open D44 front and 14-bolt rear with detroit locker. 3" body lift. Last edited by k20_chevy; 06-29-2009 at 04:28 PM. Reason: forgot something |
| put 15-40 in it keep it full, check the oil when pushing it hard, and plan on a rebuild at the end of the season
| I definitely plan on a rebuilt. Never thought about trying heavier oil.
__________________ 1981 Chevy K20 3/4 ton 4x4. 350 with th400 trans. 33x12.5x16 Super Swamper SSR. open D44 front and 14-bolt rear with detroit locker. 3" body lift. |
| gm states that if the compression is 70% of the highest cylinder let her run, but your getting on the low side, it`ll run for as long as you want you`ll just start losing power and consuming more oil later on.
| | #5 | |
__________________ 1981 Chevy K20 3/4 ton 4x4. 350 with th400 trans. 33x12.5x16 Super Swamper SSR. open D44 front and 14-bolt rear with detroit locker. 3" body lift. | |
| might want to throw a bottle of lucas in the oil, for the ten bucks its worth the try
| I will try the lucas too.
| i wold say do the test again at operating temps. the engine runs better at temp which seals better also. you will more than likely get different numbers when you do this. 85 is a good little step from 120. |
| Yea I can do it again. I'm sure my #5 cylinder is bad since the spark plug was covered in oil when I was pulling them out.
| if blowing out blue smoke, could be a future ring job, valve job or valve seal job. with the lower compression, i would lean to a valve or ring. |
| Tags |
| 350, blue, compression, exhaust, smoke |
| Chevy 6.0 compression | chevy6-0 | Chevy Truck Forum | 5 | 04-27-2009 10:32 AM |
| compression question | smokensteve | Chevy Truck Forum | 2 | 04-06-2009 11:14 AM |
| Question about checking compression | barrys | Chevy Truck Forum | 7 | 01-20-2009 03:09 PM |
| Low Compression | rbmcveigh | Chevy Truck Forum | 10 | 03-17-2008 04:34 PM |
| can you hear bad compression ? | xfrank12 | Dodge Truck Forum | 4 | 02-17-2007 11:08 AM |
