| | #11 | |
yeah thats all i mean, it may just have a little extra clearances, but i would probly knock abit. the the bypass valve is a good thing to check out. | |
| | #12 |
| Banned Join Date: Nov 2008
| Fill the engine with 5W-40 motor oil. If your pressures go up the oil pump is fine, and the bearings are causing low pressure. If the pressure stays the same the pump is bad. Easy enough. |
| | #13 |
| Senior Member Join Date: Apr 2009 Location: Lorain
| From an earlier post i have great pressure at first start but after it gets to normal operating temps i have very low oil pressure. Isn't 10w-40 thicker than 5w-40?
__________________ 1981 Chevy K20 3/4 ton 4x4. 350 with th400 trans. 33x12.5x16 Super Swamper SSR. open D44 front and 14-bolt rear with detroit locker. 3" body lift. |
| | #14 |
| No. They are both 40 weights and will behave the same when the engine is up to operating temperature. The first number is how the oil behaves cold. You said you had great pressure with cold oil so the 10W proves nothing. Try a 5W-40 and see if there is any difference. |
| | #15 |
| Alright will do. I'll update everyone by end of weekend, on what happens. Thanks everyone for your help up to this point.
| | #16 |
| Hey guys, sorry for the long delay. So I flushed the engine with diesel fuel. Then made sure it was all out and added 5w-30 oil and new filter. So I get 50psi during warm-up and 10 psi at idle in park and 5psi in gear. I'm thinking to try another pump because I read somewhere a guy tried 4 oil pumps before he got one that gave him the oil pressure he needed. I measured from the outside top of pan to botton is about 7". Anyone got any more options or ideas that I can try before I buy the pump in the link below. Melling M99HVS
| | #17 |
| it's common for an old gen1 engine to run low oil pressure. throw some lucas in and forget about it or tear it down and replace the bearings and what not after having the block hot tanked. |
| | #18 |
| Did you try the 5W-40 oil? |
| | #19 |
| No 5w-30. I'm thinking about trying straight HD-40 oil. The pressure is great at startup but falls off when it warms up. so at first start is the truck running at the 5w or the 30w using 5w-30
| | #20 |
| if you are going heavier try 10w30 or 15-40
| Tags |
| chevy, low, oil, pressure, sb350 |
| Night Owl thread | ThunderDawg09 | Off-Topic | 34 | 02-22-2009 05:23 PM |
| VolksWagen Bus Thread | peterbilt | Off-Topic | 59 | 11-26-2008 01:06 PM |
| the diet thread | mudseeker | Off-Topic | 29 | 08-21-2008 04:26 PM |
| tips thread | mudseeker | Off-Topic | 19 | 06-04-2006 01:29 AM |
