Old 07-15-2009, 08:10 PM   #1
brutis's Avatar
brutis is on a distinguished road
spun bearing 454
no 1 and 2 spun
when bearing spins in the rod do you have to replace the rod or is it possible to have it machined to work ?
it didn't spin real bad part of bearing was still there but very thin
also if i have to replace the 2 rods , i don't have to get a matched set of 8 do i ?
brutis is offline   Reply With Quote
Old 07-15-2009, 08:46 PM   #2
replace the two rods, have the cranked turned and oversized bearings put in.
Old 07-15-2009, 09:37 PM   #3
hotrodpc's Avatar
If your lucky the crank is not chewed up to the point it can not be turned. Some say to replace the rods, but if they are not very bad, you can have the big ends resized, checked true and twist at a machine shop. Becasue you do not know exactly what caused the bearing failure I would also replace the rod bolts. And all depends on the cost. If rods are cheap enough, get new ones. I think a machine will cost about $10 a rod for resizing, shot peening, check for true and twist. Bummer, one on each bank, so both heads gotta come off. If it were me, I'd probably go ahead and replace all the rod bearings while you had the pan off, and depending on the mileage maybe the mains too, along with rear main seal, but then you are talking about alot more labor, although the parts will not be much. Well, come to think of it, you are taking the crank out anyway to get it checked and turned. Go for it. All new main and rod bearings, rear main seal. Heads are off, may as well do rings too with a ball hone to the cylinders. Basically an inframe rebuild as the big trucks would call it.
Old 07-16-2009, 03:06 AM   #4
brutis's Avatar
thank you for the replys , i'll check rod prices today
i have the old 3 stone hone, is the ball hone better ?
the heads are off , the engine is out, it's a out of frame rebuild now , LOL
they spun cause the oil pump screen cloged
Old 07-16-2009, 07:33 AM   #5
hotrodpc's Avatar
Oh good. So you have easy access then to do it right. For rering job, I like to use both if both are available. The 3 fingered stone hone is normally reffered to as a glaze breaker and can clean the cylinder up nicely much quicker than just the ball hone alone, but I still use a ball hone to leave a nice cross hatch pattern in the cylinder and the rings should seat better and quicker.
wheel bearing BLK1500 Chevy Truck Forum 6 05-16-2009 06:30 AM
Bearing inside oil pan. speeder82 Ford Truck Forum 6 01-15-2009 09:19 AM
Rod Bearing Help roeckel76 Chevy Truck Forum 7 10-31-2008 02:52 PM
A/C Clutch Hub Bearing fishdoktor Chevy Truck Forum 2 07-10-2008 02:55 PM
Hub bearing HIUPCHEVY11 Chevy Truck Forum 2 03-25-2007 02:32 PM
