Results 1 to 7 of 7
Thread: 88 c10 no brake lights or turn signals?
    Sep 2009
    4
    Helping a friend troubleshoot his 88 chevy c10 pickup truck.
    1st off the headlights and parking lights work which includes the tail light parking lights. The Brake lights don't work at all and have no affect with driving lights on or off. Same goes with the turn signals & hazzard lights. Flick the switch nothing happens not even the solid dash turn light.
    Both were working fine and suddenly quit. Fuses & bulbs have been checked. I checked both switches on brake petal and both check fine. Checked for pinches etc in wiring all seems ok from back clear up to firewall behind fuse block. Only thing I couldn't check is some kind of black box with a circuit board in it up under the dash behind the radio. took it out nothing looks burnt? What is this box? It looks as the brake switch & possibly rear lights may connect to it.
    Anyone have any idea what to look for? I think he would greatly appreciate it.
    Chad
    Senior Member silverhairdeere's Avatar
    Feb 2008
    land between the lakes tn
    1,831
    try adjusting your brake pedal switch .
    shd
    crabtruck's Avatar
    Jul 2007
    5,566
    Welcome to the forum Chad.
    Don't know how you determined the fuses were good,
    but I think you need to check the fuse again.
    It is the "common to both" point. Think the fuse
    is the one 3 up from flasher unit in fuse block, not sure.
    Test with voltmeter or testlite at fuse, and if ok,
    pull flasher for haz (not turn) and check for hot at socket there.
    Be sure to post back what you find.
    Sep 2009
    4
    Of all things the turn signal switch was bad. He changed it all is working fine again.
    crabtruck's Avatar
    Jul 2007
    5,566
    Glad to hear it. Thanks for posting that back.
    Senior Member Crmzendrgone's Avatar
    Apr 2009
    Arizona
    3,218
    Dang read it to late I was going to suggest the turn signal switch. Sucks being a slow reader.
    sig by crmzendrgone
  7. #7
    Senior Member autoshopazn's Avatar
    Jul 2009
    San Diego, CA
    178
    Quote Originally Posted by crabtruck View Post
    im with him on that. Fuses are cheap and it wouldnt hurt to change them since you are in a older truck. I know that on my truck there are separate circuit boards on the tail lights but i don't see how it would affect the whole system. check the fuses
    1990 Chevy C2500 350 5.7 V8; 55 Watt 10,000K HI/LO HID Lights; K&N Air Filter; Dual Optima Red Batteries; Pioneer Head Unit w/ 10" sub; Prodigy Brake Controller; Hankook Tires; Electric Fans
  1. Turn Signals
    By curtis_98 in forum Nissan Truck Forum
    Last Post: 03-23-2009, 09:05 AM
  2. Brake Lights and turn signals
    By TZR2 in forum Chevy Truck Forum
    Last Post: 02-16-2008, 07:45 PM
  3. Turn Signals out HELP!
    By bulachip in forum GMC Truck Forum
    Last Post: 08-17-2007, 01:45 PM
  4. Need Help!! Turn Signals
    By parrott in forum Toyota Truck Forum
    Last Post: 01-07-2007, 09:46 AM
  5. !996 Chevy S10 Turn Signals
    By zbassman in forum Chevy Truck Forum
    Last Post: 12-26-2006, 08:50 AM
