Results 1 to 5 of 5
Thread: 92 k1500 - How to remove rear window and install new one
    Sep 2009
    5
    I need to install a new rear window in my truck. Before I start it and get stuck without a window because of a screw up, I was hoping someone could give me a quick tutorial on how to remove the old and install the new. I searched the site and google but couldn't find anything helpful. Thanks!
    Senior Member BernieB's Avatar
    Jul 2009
    3,880
    First, get a big rock...
    Kidding!
    It depends on the type of window you have but the most common type uses a plastic/rubber seal around the glass that has a groove in it (inside the cab). In that groove is a strip of plastic or rubber called a spline. Look for an end of the spline and simply pull it out. Now the gasket/seal has room to compress a little and you can pop the whole thing out into the bed. Installation is just the opposite.
    * SPACE FOR RENT *
    Platinum Member
    Apr 2006
    Texas
    11,159
    the one with the rubber around it, i have used a small good rope around the rubber and shoved it into the hole. once there, start working the rope back and froth and it will both seat the window where it needs to be and pull the rubber out the way it supposed to look.
    Sep 2009
    5
    Mine was the new GMC kind - No rubber seal. Simply silicone sealed on. I used the big rock theory (used a small hammer). Then cut along the inside edge of the seal after all the glass was out. Then pulled the silicone sealant off. Did the reverse putting the new one on. Used pipe clamps with a long board to hold window in place. Hopefully by tomorrow morning it will harden enough to drive. Thanks guys!
    Platinum Member
    Apr 2006
    Texas
    11,159
    cool. thanks for posting back. we know now.
  1. How do you install a driver side window in a 1999 ford ranger?
    By ErwinRommel in forum Ford Truck Forum
    Last Post: 03-23-2009, 09:03 AM
  2. What tools do I need to remove the rear disk brakes?
    By Lonesome7.3 in forum Chevy Truck Forum
    Last Post: 09-24-2008, 06:33 AM
  3. rear window leak
    By 1995C3500 in forum Chevy Truck Forum
    Last Post: 07-14-2006, 08:11 PM
  4. rear window seal
    By all4fun222 in forum GMC Truck Forum
    Last Post: 12-16-2005, 04:35 PM
  5. rear window
    By mooseye in forum Chevy Truck Forum
    Last Post: 05-16-2005, 02:38 PM
