Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 44
  1. #11
    Senior Member Crmzendrgone's Avatar
    Apr 2009
    Arizona
    3,218
    Quote Originally Posted by mudseeker View Post
    do yourself a favor and find someone with a scan tool. a failing part will not always trip the SES, but a scantool will find it. had a car in the shop one time with a stumble and no codes. put a scantool on it and commanded the egr open and closed with no change. we pulled the egr and commanded it open to 100% with the engine off. anything past 60% and the egr would snap shut, yet the pcm was still reading it as open at the value we selected.
    Good deal, I will see if my "buddies" will throw me a bone or not.
    sig by crmzendrgone
  2. #12
    Senior Member hotrodpc's Avatar
    Jul 2008
    OK
    7,145
    Quote Originally Posted by davbell22602 View Post
    What about timing belt/chain? How many miles since that was replaced or how many miles does it have on it. Check your plugs and wires. What about distributor,rotor button,PCV valve and dirty fuel injectors. Try pouring some fuel injector cleaner in your gas. map sensor too. Your egr valve might be leaking too. Check for vaccum leaks,
    Its an inline engine. Most inlines I have seen are gear to gear timing, without a chain. And as Dragon mentioned its a no dizzy. Have you ohms tested the coils Dragon? It could be a coil. But as Muderator suggested, a GOOD scanner should detect it.
  3. #13
    Apr 2009
    Arizona
    3,218
    No I did not ohm the coils I wouldn't even know what the specs would be. I don't think it is gear/gear. The Jeep 4.0L is a chain.
    sig by crmzendrgone
  4. #14
    Senior Moderator mudseeker's Avatar
    Feb 2006
    michigan
    8,354
    timing chain.............
    Attached Images Attached Images
    <----just your average 5.3
  5. #15
    Apr 2009
    Arizona
    3,218
    Yes score one for me knowing a little something. You'll have to excuse me I don't get very many "Told you so" moments so, please let me have my moment
    sig by crmzendrgone
  6. #16
    Feb 2006
    michigan
    8,354
    seems to be a DOHC with 2 intake and 2 exhaust per cylinder.
  7. #17
    Apr 2009
    Arizona
    3,218
    I'll agree as wide as the head is.
    sig by crmzendrgone
  8. #18
    Jul 2008
    OK
    7,145
    Yes, I thought of that after I posted it and was getting ready to leave the house, that is likley not going to be Gear to Gear. As many inline 4 cylinders are not either. I am still in the olden days of Chevy, Ford, Dodge Inline 6's. I really believe that also has a little to do with their longevity and not being able to kill them, as in the Chev 230, 250, 292 etc, Ford 300 and Dodge 225 crooked 6. I have not done any research on those inline 6's in Envoy and Trailblazer, but when they first came for the first year, I was working for a GMC dealership and was told the Inline Vortec 6 is a Yota motor originally. How true, I dunno.
  9. #19
    Apr 2009
    Arizona
    3,218
    Um makes me wonder. Seems like cr'ap like I said I am not a fan so far.
    sig by crmzendrgone
  10. #20
    Feb 2006
    michigan
    8,354
    not a fan of the 4.2?? seems like a peppy engine to me. could easily take my 5.0 down the 1/4 mile, even if you weighed the trailblazer down to make it fair.
  1. Trailblazer SS Exhaust...
    By 1bj in forum Chevy Truck Forum
    Last Post: 09-20-2009, 08:48 PM
  2. trailblazer wobble
    By mudseeker in forum Chevy Truck Forum
    Last Post: 01-12-2009, 08:40 PM
  3. 06 Chevy Trailblazer
    By Bonnor in forum Chevy Truck Forum
    Last Post: 12-15-2008, 02:16 PM
  4. '06 SS Trailblazer AWD...
    Last Post: 07-25-2008, 10:44 PM
  5. 04 Trailblazer Oil Light 00 454 Hard Start
    By JUS4TZN in forum Chevy Truck Forum
    Last Post: 02-28-2008, 07:15 PM
SEO by vBSEO ©2011, Crawlability, Inc.
