Old 09-16-2009, 06:18 AM   #1
jfirebird400 is on a distinguished road
clutch in a 2000 1500 4x4
I'm trying to put a new clutch and slave cylinder in a 2000 silverado 4x4 with 4.8l 5-speed. Do I need to take the transfer case off or can i slide the trans back enough without removing everything. right now i have all bellhousing bolts out and all linkage and wires disconnected and driveshafts out. i removed the trans mount but not the crossmember. I'm trying to slide the trans and transfer case back a a unit but it doesn't seem to want to come loose from the engine. or should i try to unbolt the trans from the bellhousing leaving the bell attached to the engine like in an older model. any help is appreciated. I need to get it running so i can go to work.
jfirebird400 is offline   Reply With Quote
Old 09-16-2009, 06:25 AM   #2
NCroadracer's Avatar
NCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud of
You will need to remove the transfer case from the transmission, then remove the transmission all together to do the slave cyl. There isn't enough room to do it right otherwise.
NCroadracer is offline   Reply With Quote
Tags
clutch, slave cylinder
2000 GMC Sierra 1500 Body Lean aware3218 GMC Truck Forum 5 07-28-2009 09:59 PM
2000 GMC Sierra 1500 2wd Brake Issues 00_Sierra_1500 GMC Truck Forum 11 11-04-2008 07:44 PM
2000 Sierra 1500 quit ANY ideas? dev14 GMC Truck Forum 21 09-30-2008 10:44 AM
2000 Chevy Silverado 1500 Fatcat Chevy Truck Forum 2 06-23-2008 09:10 PM
Newbie question: Considering 2000 1500 ext cab. cityhix Chevy Truck Forum 14 04-06-2008 12:53 PM
