| Full Member Join Date: May 2009
| 1994 chevy blazer 4.3 vortec I have a 1994 chevy blazer 4.3 vortec, and having a fuel problem. changed fuel pump, fuel filter, still not getting any gas. I can spray fuel in carb and it runs like a top but as soon as I stop it dies. Someone had mention the crank sensor but can not find one anywhere. Please Help. |
| do you hear the fuel pump priming up when turning the key to the on position?? do you have power to the injectors?? |
| yes fuel pump was priming, checked the pressure it was to low. put another pump in and changed the injector, now starting up running but running rough and flooding itself. any suggestions?? |
| what does the spray look like coming out of each injector?? should be a fine spray with no drips. |
| ![]() # 1 FAIR - but weak # 2 BAD - split spray pattern # 3 BAD - split spray pattern # 4 BAD - jetting on left side # 5 GOOD # 6 BAD - feathering at top of spray
| Granted that is a fuel rail but it gives you the idea.
| Vortec 5700 to Vortec 5300 or 6000 (LS-Based Swap) | bjones | Chevy Truck Forum | 3 | 02-06-2009 07:20 PM |
| 94 blazer 4.3 Vortec (again) | Hayden | Chevy Truck Forum | 25 | 08-15-2008 02:18 PM |
| 98 chevy silverado 305 vortec | robs98silverado | Chevy Truck Forum | 3 | 04-26-2008 06:47 AM |
| 1994 Full size Chevy Blazer towing.... | Pitchfork | Chevy Truck Forum | 3 | 06-21-2007 11:53 PM |
| 1994 S-10 Blazer | will4831 | Truck Classifieds | 0 | 05-02-2006 09:04 PM |
